Urgent! Unity express in Internal service Module
Dear all,
am using cme 8.6 in 2921 with internal Service Module (ISM) and couldn`t install the unity express 8.6.1 inside it
using filezella program.
am trying to install -   cue-vm-full-k9.SPA.sme.8.6.1.prt1, (size: 138.68 MB). am facing the below error when i type
service-module ism 0/0 install url ftp://cisco:cisco@192.168.1.1/tftpserver/cue-vm-full-k9.SPA.sme.8.6.1.prt1
%Error: Couldn't open ftp://*****:*****@192.168.1.1/CISCO/tftpserver/cue-vm-full-k9.SPA.sme.8.6.1.prt1.install.sre
My pc is 192.168.1.1 connecting to gig0/2(192.168.1.2)
Here is also some info:
interface ISM0/0
ip address 192.168.200.1 255.255.255.248
service-module fail-open
service-module ip address 192.168.200.2 255.255.255.248
service-module ip default-gateway 192.168.200.1
VoiceGW#service-module isM 0/0 status
Service Module is Cisco ISM0/0
Service Module supports session via TTY line 131
Service Module is waiting for registration message
Service Module heartbeat-reset is enabled
Service Module is in fail open
Service Module status is not available
Module resource information:
  CPU Frequency: 1068 MHz
  Memory Size: 493 MB
  Disk 0 Size: 4110 MB
No install/uninstall in progress
Can someone please help to solve my issue as i change the directory too of the cue file....
thanks
16 Replies 16
Terry Cheema
Can you ping cue from your pc? Do you have a static route for CUE ..?
If not add :
Ip route 192.168.200.2 255.255.255.255 ism0/0
Dear Terry,
thanks for your replay,
already done in the router but the same issue is still there. only I didn`t type it in my previous post.
regards,
In addition to the previous info i can do ping from my pc(192.168.1.1) to the ISM 0/0(192.168.200.1) and vice versa, but i can`t ping the service module(192.168.200.2) from my pc neither from the router itself.
thanks
Yes, the service-module ip address is pingable. But it won't ping if the interface of the service-module ip default-gateway isn't connected to a routing network, and instead connected to a pc in your case. For some reason it causes the packets to go to a routing black hole.
Stores_Router#show run | s interface SM1/0
interface SM1/0
 ip unnumbered GigabitEthernet0/0
 service-module ip address 10.121.44.200 255.255.254.0
 !Application: CUE Running on SM
 service-module ip default-gateway 10.121.44.192
Stores_Router#
Stores_Router#ping 10.121.44.200
Sending 5, 100-byte ICMP Echos to 10.121.44.200, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
Stores_Router#
paolo bevilacqua
Use FTP server, not TFTP..
Dear Paolo,
am using FTP filezella program, of course am not using the tftp .
can you help as i realy got fed up .............
thanks for your post.
You are also using the wrong command.
You install .pkg files, not .prt1 file.
Hi Paolo,
I have downloaded the previous prt1 file and also a zip file (153 MB) which contain the following:
cue-installer.SPA.sme.8.6.1                             (10MB)
cue-vm-full-k9.SPA.sme.8.6.1.prt1                     (142MB)
cue-vm-installer-k9.SPA.sme.8.6.1.prt1             (140Kb)
cue-vm-k9.SPA.sme.8.6.1.key                          (1KB)
cue-vm-k9.SPA.sme.8.6.1.pkg                          (171KB)
cue-vm-k9.SPA.sme.8.6.1.pkg.install.sre           (38KB)
cue-vm-k9.SPA.sme.8.6.1.pkg.install.sre.header (1KB)
cue-vm-langpack.sme.8.6.1.pkg                         (3MB)
which file i must install and what is its minimum size? Is my error issue relates to the type of the file???
thanks again for cooperating.
The pkg as mentioned before. You also need at least one language file.
Ok,
I tried to install the cue-vm-langpack.sme.8.6.1.pkg   (3MB) and the Language file cue-vm-en_US-langpack.sme.8.6.1.prt1 (30 MB),,,,,,,,, but still the same error:
%Error: Couldn't open ftp://*****:*****@192.168.1.1/CISCO/tftpserver/cue-vm-langpack.sme.8.6.1.pkg
How i can solve this issue, I gave up.
thanks Paolo.
Check if FTP server gets any connection attempt.
If it doesn't, reconfigure CUE interface to be in same subnet as router.
Dear Paolo,
here what I did.
I check the conncection with ftp by copying a test file from my pc (Act as ftp server) to the router flash and it works successfuly, but to the ISM it doesn`t.
I change the configuration of the ism 0/0
interface ISM0/0
ip unnumbered GigabitEthernet0/2
service-module ip address 192.168.1.10 255.255.255.0
service-module ip default-gateway 192.168.1.2
hold-queue 60 out
interface GigabitEthernet0/2
ip address 192.168.1.2 255.255.255.0
duplex auto
speed auto
hold-queue 60 out
ip route 192.168.1.10 255.255.255.255 ISM0/0
Still i can`t ping 192.168.1.10, is it a pingable or not??????????????
THEN
VoiceGW#  service-module ism 0/0 install url ftp://admin:admin@192.168.1.1/E:/CISCO/tftpserver/cue-vm-langpack.sme.8.6.1.pkg
Proceed with installation? [no]: yes
%Error: Couldn't open ftp://*****:*****@192.168.1.1/E:/CISCO/tftpserver/cue-vm-langpack.sme.8.6.1.pkg.install.sre
Execution of script cue-vm-langpack.sme.8.6.1.pkg.install.sre failed, installation aborted
VoiceGW#
How this can be solved??????????????/
thanks again
Andrei Fokin
Mohammed, may be my similar configuration help you. I have 2911 with UMG Service Module:
interface GigabitEthernet0/0
description To_LAN
ip address 10.0.3.23 255.255.255.0
duplex auto
speed auto
interface SM1/0
service-module ip address 10.0.3.24 255.255.255.0
!Application: Cisco UMG running on SM
service-module ip default-gateway 10.0.3.251
ip route 10.0.3.24 255.255.255.255 SM1/0
Thanks Andrei,
I did as you told me but it doesn`t work,,,, see my above post.
Any another solutions.....???
thanks
