Management
Intro to Ansible
Good Documentation
The Great Selenelion
>> View previously featured conversations <<
Hi,Trying to request certificates via API.CSR create works only it does not use the altNames list.Also when using multi-server as distribution, it returns a error  "Invalid Distribution!".and i mis the option to include the OU. like via the webpage.I...
Rons by • Frequent Visitor
  • 136 Views
  • 0 replies
Hi,Looks to be a bug in XBusyLampField in 11.5 AXL.The schema is: <xsd:complexType name="XBusyLampField">         <xsd:sequence minOccurs="0">             <xsd:element maxOccurs="1" minOccurs="1" name="blfDest" type="xsd:string">                 <xsd...
I have don't quite a bit research and didn't seem to find a perfect answer. It's a simple task for RTMT to find the number of registered phones in a cluster.  Not so simple from application perspective.   Method 1: Use Risport70 API (https://develope...
luoht by • Visitor
  • 4461 Views
  • 5 replies
Resolved! GAXL
Hi,can anyone explain what GAXL is? Reference seems to be a comment in a response to calls like listPhoneButtonTemplateResponse.<!--This API has been processed by GAXL not AXL-->this is not in all axl responses. Annoyingly the namespace has changed f...
levinsky by • Level 2
  • 3403 Views
  • 4 replies
We are using AXL API to update line CSS. We are updating based on DN. In CUCM we have created 2 CSS as CSS1 and CSS2. We want to change CSS from CSS2 to CSS1. Our code is as below -UpdateLineReq objUpdateLineReq=new UpdateLineReq();XFkType xfkCSS = n...
Hello.Has anyone had any luck getting with  UCM 15.0(1) and getting this API to work for Identity Certificates to upload?  The tomcat one.post....../platformcom/api/v1/certmgr/config/identity/certificatesI read this is required?{ "service": "tomcat",...
jwilson by • Level 2
  • 1246 Views
  • 2 replies
Hello, I am working with the Call Handler API. The general Call Handler list API gets all objects in the system, mailboxes, default objects etc. I am looking to have just the objects on the "Call Handlers" page be returned in my query, but can't figu...
Hello, I'm attempting to use the CER REST API as documented here: https://developer.cisco.com/docs/cer-config/erl-management/ against a CER 14.0 cluster. My goal is to assign ERLs to access points. According to the documentation, this can be done wit...
We have a ANAC box on our soon to be powered down PBX. It says the extension you are calling from when called. It's a helpful piece of kit that comes in handy when you're trying to ID an analog DN on an ATA in the field. Has anyone built anything lik...
