Network Management
Labels
We are aware and actively investigating issues with SAML SSO failures. Customers may experience log in errors with page not found. A workaround is removing the /login/saml/email_verification from the end of the URL. This is being investigated as a pr...
CallyH by • Cisco Employee
  • 238 Views
  • 1 replies
Resolved! SNMP at 5s and 6s
Hi There,Was wondering if someone has come across this before.I'm polling a couple very limited SNMP OIDs (ifHCInOctets/ifHCOutOctets of some interfaces) at high intervals on Catalyst 9300 class switches.At 5s, the ifHCInOctets/ifHCOutOctets is very ...
alexgill by • Visitor
  • 895 Views
  • 7 replies
Hello everyoneI want to know if you change your clock configuration each year or not ? I mean what do you do to change the summer-time each year? Because the date and the day will change every year.I mean, this year the summer-time is : 10 Mar and 3 ...
Historically I've heard of certain commands appearing in a different order for the same device configuration. In the startup config for instance you might see subcommand B before subcommand A, even if for the same configuration you used to see A befo...
amcc by • Community Member
  • 290 Views
  • 3 replies
Hi,Im fiddeling with various EEM applets and feel a bit held back by the lack of documentation. Or maybe my google-searching skills have declined. First: Is there an official documentation of variables somewhere? So far I have pretty much brute-force...
eekman by • Level 3
  • 5079 Views
  • 12 replies
adquirí 3 router, lo configure a través de consola, funciono muy bien como repetidor Wi Fi, pasado unos años de pronto comensaron a parpadear las luces de verde a naranja y a rojo y se perdio el Wi Fi. los resetee volvi a configuralo pero con la wi f...
