If you have any features/improvement suggestions, let us know below.
I'm migrating from MSO to NDO and have a few APIs that we use to monitor and configure things in MSO.Will those APIs continue to work after migrating to NDO, or do MSO and NDO have completely different APIs?
is there any conversion at nexus switch end when it rececives an offer for rtprefix against option 243 ?What is the correct method or way to registering rtprefix (option 243) in a DHCP server?Basically I am trying to boot a nexus 9K device usign POAP...
<p>I have tried to use the RTPrefix value type <strong>string</strong> and configured the value <code>3600 80 1 280e:c0bc:216e:1920:10::</code> in CPNR. But the RTPrefix value my NX-OS device is interpreting is something absurd. I have no clue how to...
Hi experts,Apologies for posting something that is not a QA topic, but I would like to humbly introduce a tool that may be useful for some of you.We have added support for Cisco Nexus Dashboard to Network Sketcher, an OSS tool for creating network co...
Is the NDO API backward compatible?I have two Nexus Dashboard deployments for different sites:Nexus Dashboard 3.2.1e (newer)Nexus Dashboard 2.1.2d (older)The following API works on the newer version but does not work on 2.1.2d:GET /mso/api/v1/nodesIs...
We are running into issues with ACI inbound management towards the Nexus Dashboard, because traffic to the VMM integration is also starting to flow through the inbound interface, while we want this to go over out-of-band. I believe the issue has been...
I've a question concerning the setting of Overlay-mode on NDFC. The config-profile is the default setting once you have to bring-up a VXLAN fabric using NDFC; let's suppose that at a cert point, we want to introduce "security-group" with GPO and cont...
Hi, I am relatively new to NDFC. I have some Palo Alto firewalls that are setup like below. VXLAN SW1 E1/10 <-> Palo Alto E1/1 - Palo Alto E1/2 <-> VXLAN SW2 E1/10VXLAN SW1 E1/11 <-> Palo Alto E1/3 - Palo Alto E1/4 <-> VXLAN SW2 E1/11 When we do th...
Hi, all, i'm facing an issue while installing NDFC on a ESXI server. please check the following image.It's still not working even i execute the command "acs upgrade recover AppActivate".Anyone can help me on this? Thanks.
HelloI have configured a vxlan fabric and would like to have layer 2 extension to external fabric. I have created the L2 network in Cisco NDFC and attached it to the endpoint access port and port channel on the BGW connected to the external switch. T...
nx-os 10.5(1) (C93600CD-GX, C93180YC-FX3, C93108TC-FX3)nexus dashboard 3.2.2minsights 6.5.2.56currently dashboard is empty - no data appear despite switches- connectivity to insights status indicates OK (insights)- fabric connectivity to nexus dashbo...
Hi fellow members, deploying a NXOS based fabric using NDFC and came across the concept of "multi-attach" and "multi-detach" of networks and VRFs. When coming from an ACI world, this does not exist there. Every network/BD and VRF when created is depl...
Hello Community,I'm trying to install Nexus Dashboard 3 Node Cluster on ND-NODE-L4.I'm using version 4.2(1) (via nd-dk9.4.2.1.10.iso)The Cluster Bringup already failed with: The Setup is L2:All 3 Nodes are reachable over Mgmt- and Data-Network.Mgmt- ...
I tried to configure SNMPv3 for the N9K switches, but I could only find the SNMP user template and could not find the SNMP group template.Could anyone advise on the correct template name? or how to configure it without freeform.
I have been reviewing the Nexus Dashboard sizing tool as well as release notes and now I got more questions than answers...Hope someone can help.I got several "leftover" ND-NODE-L4 appliances and I would like to use them to build a greenfield cluster...
| Subject | Author | Posted |
| 08-18-2026 12:58 AM | ||
| 08-18-2026 12:26 AM | ||
| 04-16-2026 09:16 AM | ||
| 03-06-2026 08:04 AM | ||
| 02-26-2026 03:34 PM |
