What is the difference between SNCP and MSP Linear .Is there any other protection type?Thx.
I have two 3750X switches that need to connect using SFP-10G-LRM GBIC over 62.5/125 OM1 MMF. It's a short distance, the buildings are not more than 75 feet apart. Each switch has a C3KX-NM-10G network module installed. There is a mode conditioning...
Hello Community, I have question about Nexus 93180YC-EX. Can we used ports as 1gb and 10gb at the same time ? Did mixed of 1gbs and 10 gbs are possible with first 48 ports ? Regards,
I'm looking to connect to an ISP circuit. The fiber run is single mode and they have a 100 Base FX transceiver on their end.I've looked up the specifications on that transceiver and it say's it should only be run on SMF. Anyone had any success with t...
Dears, can anyone advise why when i configure privilege level 0 without aaa enable it is taking privilege 0 commands as below but when enable aaa then privilege treated as level 1. privilege level 0 — Includes the disable, enable, exit, help, and...
Environment: We have built an environment with DNA Center 1.2.1 that contains1 bordernode C9500-24Y4C1st EDGEnode C9300-48PWhere the border node is connected to an external router with AS 65000 (asr920)The SDA environment has AS 65244 Issue:We are ha...
Got a flapping link between 2 of my MLSwitch (both are Cisco 6800-XL).int Te7/3 on MLS_1 to int Te7/1 on MLS_2the fiber connector on MLS_1 is SC, while the fiber connector on MLS_2 is LC I have changed the fiber cable (Single-mode LC-to-SC) and I hav...
hola tengo un problema como configurar un acces point WAP131. me podrían dar una mano por favor
Hello, I was wondering. I have 2 3750 stacked. One of it had an issue with the fan and had to take it out. I ordered a new one but it came with a different image as the one that is working right now. The new one has c3750-ipbase9-mz and the old hta...
Hi all!We have Cisco QSFP-100G-LR4-S transceiver and Mellanox ConnectX-4 VPI - PN MCX456A-ECAT card.After set transceiver into the card, 100Gb link wasn't up.In the datasheet for the card (http://www.mellanox.com/related-docs/user_manuals/ConnectX-4_...
Hi,i have configured a multicassis etherchannel between some catalyst 2960x and two C9500-x configured in stackwise virtual. I''m encountering this issue, when i boot all the stackwise at the same time the LAG work proprely, but if the only standby m...
Hi Team, Can we use GLC-LH-SMD for 10km transmit ?
Hi,Could someone help on this? SFP-10G-LR-S is not recognize by my brain new switch. Hardware: C9300-48P-eModule: C9300-NM-8X (8x10G Uplink Module)IOS VER: Version 16.8.1r [FC4] Don't know why and what to do. need to install my system tomorrow.Please...
Dear Experts, I have been told to design the network for our new project. I have been told to consider the redundancy and stability of the network. honestly i have never designed for a big project. I would be really grateful, if you could help me to...
Subject | Author | Posted |
10-07-2024 12:40 AM | ||
10-04-2024 12:50 PM | ||
09-24-2024 09:19 PM | ||
07-25-2024 01:25 PM | ||
05-05-2024 05:19 AM |
