02-08-2005 06:52 AM - edited 03-13-2019 07:56 AM
Hello All,
I am trying to find out exactly how to associate users with phones using the BAT spreadsheet in CCM 4.0(2a).
This worked just fine in 3.0 and now although it adds the users and phones it does not show the phones as controlled devices by the corresponding users.
If someone will be kind enough to,very explicitly, explain the process I will be sure and rate their post.
02-09-2005 08:21 PM
This problem still exists in 4.1x
I too would love to know how to fix this. Is there another bat tool to download? The Bat.xlt that is on the 4.1 server has errors in it too. I hope there is another one available as I have 700 phones to do next month.
02-11-2005 06:18 AM
It seems that BAT phones are associated but when TAPSed they are no longer associated. Is there a fix for this behavior?
02-17-2005 02:38 PM
Same issue...Just wanted to add myself to this thread
04-23-2012 06:18 AM
I want to add myself in this thread. I want to ask you if you know any way to update owner user ID field for 1+ users
simultaneously via BAT? I tried via Phones>Update Phones>Custom Query, but there is no way, coz user ID is a unique information for each user. Is there any easy way to do it instead of make it by hand?
04-23-2012 10:14 AM
You'll need to use BAT in a different way. You will need to create a CSV file, which holds the devicename to userid mapping, and then upload it to the CUCM server, followed by updating the users.
Summary
You will need a list of your users userid's if you don't have it already. If you don't have it, you could get it from a BAT > Users > Export
Once you have the file with the userid, you need to assign each user to a device. Here's an example of what that file will look like, but with just a single test record.
update-users.csv
FIRST NAME, LAST NAME, USER ID, CONTROLLED DEVICE 1
Anthony,Holloway,aholloway,CIPCAHOLLOWAY
Next, you need to upload it to BAT under BAT > Upload/Download Files
Last, you need to update the users in BAT under BAT > Users > Update Users.
04-23-2012 11:22 PM
Hi Anthony,
Thank you for your prompt response, but I do not think that this is what I need. I know how to associate user with controlled device. The
truth is that I need to assign Owner User ID on the Phone's configuration field. I need it for Cisco Jabber IM client.
04-24-2012 12:48 AM
In that case you need to follow Anthony's instructions, but export, modify and import the phones instead of the users.
Aaron
04-24-2012 01:04 AM
This will not gonna help, because you've already configured the phones. In this case when you will try to insert the phones you will receive the following error:
000F345AA615 DEVICE :: Error : Could not insert new row - duplicate value in a UNIQUE INDEX column (Unique Index:x_device_name).
04-24-2012 01:38 AM
There's no option to overwrite?
I don't have CM4 to hand, but recent versions don't overwrite unless you tell them to to prevent admin errors.
04-24-2012 01:41 AM
Damn it, you're right! I forgot the overwrite option (facepalm) .
Thank you!
04-24-2012 02:42 AM
No problem!
Please remember to rate posts you have found useful and mark 'answered' if appropriate!
Principal Engineer at Logicalis UK
Please rate helpful posts...
