Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3058 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4636 Views
  • 1 replies
  • 16 Helpful votes
All, I am part of the CUCM TAC team and please bear with me as I do not handle much of the networking/switching aspect and really have no clue when it comes to the switches I am asking about. I've done some research and I can only find documentation ...
dgrup by Cisco Employee
  • 1575 Views
  • 2 replies
I'm new to this forum and not too technical. I would like to connect a non-VLAN aware router to port 1 (or other port), create VLAN 2 and VLAN 3, connecting computers to them. Can the SG200-08 be configured to allow all devices on the VLANS to get to...
dgkurtz by Level 1
  • 687 Views
  • 0 replies
My Native/Default VLAN is 1. I have 2 other VLAN 20 and 200. From those VLAN I could not access my SG300-28P switch. Default VLAN 1 IP range 10.10.0.1 - 10.10.0.255 Static VLAN 20 IP range 10.10.1.1 - 10.10.1.255 2nd Static VLAN 200 IP range 1.0.0.1 ...
Hi all, I created 2 vlans in my switch Vlan10 192.168.1.1  Ports 1 to 12  (all untagged for this vlan) Ports 13 to 24 (excluded) Vlan 20 192.168.99.1 Ports 13 to 24 (all untagged for this vlan) Ports 13 to 24 (excluded) IPv4 Interface already configu...
diegog by Level 1
  • 901 Views
  • 2 replies
Hello all, Just a quick question; I have a router with ip 192.168.1.248 connected on a L2 switch, and all pc's are using this as the gateway.From the L2 goes a cable to a SF300 L3 switch, on this switch i have three Vlan's; Vlan1 ------> 192.168.1....
GBonset05 by Level 1
  • 468 Views
  • 1 replies
I did not know to update the boot software of my SRW2024 first, then update to 1.2.2b.I need to go back to the 1.0.0.86 firmware.Is it downloadable and will it work (ie work backwards and then do it properly)?  I know how to use hyperterminal and the...
peters1536 by Level 1
  • 2421 Views
  • 10 replies
I'm trying to upgrade a number of RV042s to v3.  I'm trying to update the firmware to the latest on those that already are in production and need to access them. I'm having a lot of trouble doing this. It appears that IE isn't suitable. On one situat...
fmarshall by Level 1
  • 437 Views
  • 0 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
