Switching
Labels
Welcome to the Cisco Community Ask Me Anything conversation. Submit your questions from Monday, February 2, 2026, through Friday, February 20, 2026. Our colleagues Amruta Navadagi, Anaya Kalawat, and Mohammad Mehtabuddin will be waiting to assist you...
amnavada by Cisco Employee
  • 5553 Views
  • 29 replies
  • 1 Helpful votes
Hello All,I have a query if I may.We have recently procured few 9350-hx switches. We have several 9300-48u and 9300-uxm in production. We tried stacking the new 9350s as we have 9300s stacked. But it would not work as in the stack members wont show c...
Hello,We have currently 2 WLC 5520 connected on a Catalyst 3850 stack, via port-channels, and mode on (no lacp).We will replace our Catalyst 3850 stack with 2x Nexus C9K-C93360YC-FX2, I've configured a port-channel with mode on, and a vpc for the red...
Clem58 by Level 6
  • 58 Views
  • 3 replies
I have a Catalyst 2955 that has ignored all my attempts to interrupt autoboot with the Break sequence.  I have tried PuTTY, TeraTeSwitching, Catalyst 2000, Other Switchesrm, and HyperTerminal, pressing Break, Ctrl-Break, Ctrl-B, -C, and spacebar at 3...
nlsa by Level 1
  • 642 Views
  • 17 replies
This week I finally got a maintenance window to be able to upgrade one of our pairs of C9500-12X pairs to a version supported by the Meraki dashboard.The ISSU upgrade (from the CLI) worked perfectly from 17.9.5 to 17.15.4 and took about 35 minutes.St...
CMR_1-1776345488832.png CMR_2-1776346098423.png CMR_3-1776346424412.png CMR_5-1776346561882.png
CMR by Meraki Community All-Star
  • 833 Views
  • 13 replies
Does anyone know of an on-line calculator which can be used to predict which member of an LACP channel will carry the packet, given source / destination MAC address (or IP address or TCP port)?I've found tutorials on how to perform the XOR/modulo cal...
Hi All, Good day all. Just want to ask help for inputs on below. Query from client. I don't much experience with ISE and dot1x. Any inputs would be appreciateClient Queryhave started to implement 802.1x Wired for VOIP in our environment using Cisco I...
arfernan by Visitor
  • 401 Views
  • 5 replies
Hello, our 9200 switches with code 17.9.4a receives dacl from ise and authorize clients successfully. Based on the complaints (endpoint can access to destinations that they shouldn’t as destinations not allowed in DACL) we started to see if anything ...
tungrwaga58 by Community Member
  • 647 Views
  • 4 replies
Hello everyone i see logs on the switch.%SYS-2-MALLOCFAIL: Memory allocation of 395648 bytes failed from 0x1AE504, alignment%Error on initialize VLAN database 1: VTP feature not yet initialized[OK]googled this issue, found memory is low, how to solv ...
Mlex1 by Spotlight
  • 426 Views
  • 6 replies
