04-25-2015 04:37 PM - edited 03-19-2019 09:31 AM
I’m running into an issue installing the secondary/subscriber Unity Connection (CUC) server at a client. It keeps on failing the validation and not allowing me to continue:
I have removed and re-setup the server on the Primary/Publisher CUC using both hostname and IP address 3 times now to no avail. I can ping the server being installed from the Publisher/Primary without issue. Other Pub/Sub servers between the subnets installed without issue.
Does anyone have any thoughts on what I could try next? Has anyone seen this before?
Any help much appreciated!
Solved! Go to Solution.
04-29-2015 05:22 PM
I ended up using the "Back" button on all the install screens till it allowed me to shut down the guest. Then I powered the VM back on and restarted the install once again and worked the second time around. Nothing was changed. Very odd.
Thank you all for your suggestions!
04-25-2015 09:26 PM
Can you check if NTP sync is working correctly between Pub and NTP server.
Manish
04-27-2015 06:49 AM
Hi there,
+5 to my friend Manish for his good tips!
It sounds like this bug;
Symptom:
Subscriber installation does not indicate Security Password mismatch.
Error on Screen:
Configuration validation with cucpub (x.x.x.x) failed.
This node is not found in cuc10's server configuration.
- Is cucpub entered correctly?
- Is cucpub the correct first node for this node?
Other details like Hostname/IP Address of Publisher are entered correctly. This error is misleading.
Conditions:
Seen on all versions of Unity Connection and CUCM
Workaround:
N/A
Cheers!
Rob
| Known Affected Releases: | (1) |
02-22-2017 08:08 AM
Guys, we need to add the Sub into the cluster page on the Pub before we start the installation of the sub, right?
02-22-2017 09:52 AM
Hi Velin,
That is most correct my friend!
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/install_upgrade/guide/10xcuciumgx/10xcuciumg010.html#pgfId-1428513
Cheers!
Rob
02-22-2017 10:35 AM
Thanks, Rob! I'm hitting the same bug described in the first post. I will try it again tomorrow with the workaround described here. Any other suggestion?
06-14-2017 06:45 AM
I am installing CUC 11.0 Subscriber and i have done all the pre-configuration in CUC Publisher like i have added subscriber details in cluster and activated all the services in serviceability page and also restarted the server.
But i am getting this "critical error". Here i have uploaded image of cucm but i am facing this now for cuc.
06-14-2017 08:00 AM
Guess you are hitting this:
https://supportforums.cisco.com/discussion/12879341/installation-cuc-110120000-2-failed
Rajan
Pls rate all useful posts
04-27-2015 06:41 AM
Hi there,
In addition to the good tips from my friend Manish (+5), it sounds very much like you are hitting this bug;
Cheers!
Rob
04-29-2015 05:22 PM
I've triple checked this during my first install attempt. I posted a reply on this but all I did was restart the install and it worked.
04-29-2015 05:22 PM
12-18-2015 12:29 PM
Thanks koziollz
I had the SAME problem with Unity ver 11 , and I followed your recommendation.
I can not believe it.
Best regards !!!
Enrique
12-30-2016 03:09 AM
Same here. CUC subscriber installation 11.5.1.11900-26. I've checked everything after going all the way back power down and then power up again everything worked fine!!!
04-27-2020 04:14 PM
Same thing with CCX Sub and work fine after VM back again!
01-05-2017 12:28 PM
11.5.1.11900-26 - same condition
SUB1 went in fine.
SUB2 required this process.
Backed out, bounced the VM, let it continue and all was well.
