- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-11-2022 03:38 AM
Hi folks,
i was stepping on the following issue.
The ASR1001-X is EoL, the repleacement product is the Catalyst 8500L. However C8500L does not support CUBE but ASR1001-x was.
CUBE guide suggests using the C8300, however these boxes have diffrent hw-specs (fewer ports and not OOB MGMT Port).
any thoughts ? Will the C8500L support CUBE in near future ?
Thanks!
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-12-2022 05:32 AM - edited 11-12-2022 05:35 AM
We cannot discuss roadmap plans here; that requires an NDA. Ask your Cisco account team directly.
That said, the 8300 series are VERY capable boxes capable of significant scale for CUBE - easily as much as an ASR 1k-X was. The 6T models have more ports than an ASR did, any of which can be a management port if you put it in a VRF.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-14-2022 02:18 AM
Thanks Jonathan,
we will contact our account Team.
As a quick and available solution we will use the C8300-2N2S-4T2X with C-NIM-1M (Cisco Catalyst NIM Module 1-Port 2.5mGig with PoE) as OOB MGMT Port.
Yves
