Field Notice 70545
1608
Cisco UCS Management Pack with a SCOM 2007 R2 Gateway
we are trying to monitor a Cisco UCS deployment using the UCS management pack. The UCS is in a different network, so we are using a SCOM gateway server to monitor it. However, the UCS management pack appears to be trying to connect to the UCS from the root management server, as opposed to from the gateway. As a result it is not working, because the RMS server doesn't have direct access to the UCS web interface. Is using a SCOM gateway supported with this management pack, and if not are there any plans to support it?
0 REPLIES 0
Create
Recognize Your Peers
Content for Community-Ad
