Unified Computing System Discussions
Engage with peers and experts on UCS and HyperFlex topics.
I could use some guidance. I have not tried support yet from either Cisco or VMware but here is my struggle. I have an environment with probably 15 - 20 b200m5 blades. They are all set to legacy bootThey all boot local via local disks configured in a...
jn242 by Level 1
  • 610 Views
  • 3 replies
Hello Cisco Community, I’m setting up a home lab using a Cisco UCS C220 M3 server and would appreciate some guidance on finding a compatible hypervisor. I’ve tried installing VMware ESXi (7.x and 8.x) and Proxmox VE 9, but both failed due to hardware...
Hello,I’m preparing to deploy a Windows Server 2025 Hyper-V cluster on a Cisco UCS X9508 chassis, and I’d like to understand the best practices for this setup.In particular, I’d appreciate advice on the following points:Recommended firmware versions ...
Hello, Cisco Community.I studied working with UCS 6300 in gui. Initially, I had an ethernet port configured in vntag mode. A c240 server was connected to this port.As part of an experiment, I reconfigured the port in Apliance. I lost connection with ...
yak-dva86 by Level 1
  • 252 Views
  • 2 replies
Resolved! Firmware Upgrade
Cisco UCSM running B200 M5'sToday I was performing infrastructure and server firmware upgrades.  My upgrade was going from 4.3(2f) to 4.3(3c).  The infrastructure upgrade was successful.  After creating my new host firmware package and modifying my u...
TroyS by Level 1
  • 399 Views
  • 1 replies
