Unified Computing System Discussions
Engage with peers and experts on UCS and HyperFlex topics.
Hello,On C480M5 - CIMC is setup and is accessible via shared LOM.  Now I've this major warning and I want to get rid of it.  Please advise. Thanks F0717 - sys/rack-unit-1/mgmt/if-1  link missing  Management Interface Link Down: LOM_P0 Check the netwo...
SamUrai by Level 1
  • 318 Views
  • 3 replies
I could use some guidance. I have not tried support yet from either Cisco or VMware but here is my struggle. I have an environment with probably 15 - 20 b200m5 blades. They are all set to legacy bootThey all boot local via local disks configured in a...
jn242 by Level 1
  • 1054 Views
  • 9 replies
Cisco blades has a vKVM-Mapped vDVD1.22 boot option and boots to some sort of isolinux. How do you delete this ISO file/boot option in the bios and where is it saved on the server? All of the media has been wiped? I did a factory reset and scrub thro...
Hello Cisco Community, I’m setting up a home lab using a Cisco UCS C220 M3 server and would appreciate some guidance on finding a compatible hypervisor. I’ve tried installing VMware ESXi (7.x and 8.x) and Proxmox VE 9, but both failed due to hardware...
