07-16-2012 07:10 AM - edited 03-21-2019 06:02 AM
On a UC560, is it normal for a 9971 to re-register itself to the UC every 10 mins?
Without fail it happens. Whilst the phone is re-registering it says "Not Registered" and then reconnects.
Only noticed this happening after I configured a SIP trunk. So im not sure if its a coincidence. All configured with CCA:
voice register global
mode cme
source-address 192.168.100.254 port 5060
max-dn 56
max-pool 14
load 9971 sip9971.9-2-2
load 9951 sip9951.9-2-2
load 8961 sip8961.9-2-2
authenticate register
timezone 43
time-format 24
hold-alert
voicemail 399
tftp-path flash:
create profile sync 0001402427654588
11-14-2012 07:11 PM
basically, this is caused because TCP againg timer (5 min default) is less than registrtion refresh timer, and the TCP session closed. please try 2 options
1. increase aging timer
sip-ua
timer connection againg 70 -> 1 + hour
or
2. decrease regisrtation refresh timer
voice service voip
sip
registrar server expires max 300 min 150 -> 5 minute
please update the any result.
11-19-2012 11:20 AM
Thanks for the reply, we have tried your second fix and whilst it has stopped them rebooting some of them do seem to drop their incoming extension.
E.g the phones can dial out but will not accept incoming calls.
Any ideas on this?
Best regards,
Tim
11-19-2012 11:47 AM
seems like, you hitting another issue,
i believe that you saying that call droped, SCCP phone to 9971, and you have SIP trunk configured which use outbound proxy, if that is your case, please try this.
no outbound-proxy
if this is not your case, then what is detail of call flow and please collect debug when it failed
debug ccsip mess
11-19-2012 12:00 PM
Hi Bongsu,
All the 9971 phones register ok and work fine but after a while some will not take incoming "internal" calls from other extensions.
If we delete the phone and re-add it in CCA it then works but may stop receiving after some time. Simply rebooting the phone does not help.
All the phones are 9971 or 8961 and of course all running SIP, we do not have any SCCP phones on at the moment. We do have an outbound sip trunk and PSTN lines.
11-19-2012 12:48 PM
Also I have just checked and we already have "no outbound-proxy' in the register global section.
11-19-2012 01:07 PM
so a call from SCCP phone to SIP phone failed.
please send me the debug ccsip mess, show run, show ver. at bkwon@cisco.com
07-14-2015 12:46 PM
Thanks bkwon.
Since enabling SNR on SIP 8800 series phones, they started re-registering every 10 minutes.
Using show sip-ua status registrar showed 4 TCP connections for each extension that had SNR enabled.
Part of SNR is to enable session-transport tcp, the other phones were using UDP so it was never a problem for them.
The second solution worked for us.
03-10-2013 01:58 PM
I had the same issue of 9971 phones getting re-registered to CUCM 8.6.2.22900 via wifi less than every 10 minutes.
Figured out that QOS setting on Cisco AP was least priority for VOICE SSID.
The issue was resolved when QOS setting (on Cisco AP) for Voice SSID was changed to PLATINUM.
Hope this helps.
Rgrds
04-23-2013 02:13 AM
I am also facing the same porblem. My phones are also going registered and un-registered after 10 mins... Anyone find the solution for that ?
04-23-2013 02:39 AM
Hi fahad,
What environment is yours? 9971 is registered with CUCM or CME?
Is 9971 connected via wifi or wired?
Rgrds..
04-23-2013 02:58 AM
thanks for your quick reply...
I configured cisco 9971 with Cisco CME ver 9.1. All the phones connected thorugh wire.
04-23-2013 05:47 AM
Could you prrint your onfiguration of:
04-23-2013 03:30 PM
Please find the below.
mode cme
source-address x.x.x.x port 5060
timeouts interdigit 3
max-dn 25
max-pool 25
load 9971 sip9971.9-2-2SR1-9
timezone 31
time-format 24
tftp-path flash:
create profile sync 0266545455593711
voice register dn 1
number 4000
allow watch
label Reception
voice register pool 3
registration-timer max 720 min 660
id mac 64D9.89C2.CDAE
type 9971
number 1 dn 3
dtmf-relay rtp-nte sip-kpml cisco-rtp sip-notify
codec g711ulaw
camera
04-23-2013 06:44 PM
Hi Fahadqureshi,
Insert these configurations bellow and all phones will work fine!
voice register pool 1
username xpto password xpto
The username and password can not be the same for each voice register pool. In my configuration I am using the username and password as the number of voice register dn.
Ex:
voice register dn 1
number 4701
id mac D4D7.48FF.C1FB
type 9971
number 1 dn 1
username 4701 password 4701
codec g711alaw
no vad
camera
video
I have had problems with transfer calls and for resolve this issue I am using the codec g711alaw, but you are using this codec
Try this configuration and if works, report to us.
04-25-2013 01:42 AM
Dear Fabio,
Thank you so much in this.. This work perfectly fine.. Really thankfull to you. You are the only person who resolved this issue and guide me in a proper direction.
Thanks and takecare.
Best regards,
Fahad
