Voice Systems and Accessories - Small Business
Upgrade your communication system with our Voice Systems and Accessories, perfect for small businesses.
Hi.Are we allowed to edit phone dictionaries for fixing cyrillic numpad?We found that in 504/525 there was degrade in numpad translation.Lots of symbols missing. Inside of xml dictionaries we found keymap section 525:<!-- #############  KEYMAP ######...
Hi,I'm a total newbie in using Cisco phones, but I've noticed that when I reject a call on my SPA504G, that call is not a "lost" one (it would be in almost every mobile phone firmware, for example), and not a "received" one too (!).So, rejecting a ca...
I have an SPA232 with a couple of SPA302 handsets.  I want to add the blind transfer and remove the regular transfer.I found the setting (Blind Attn-Xfer Enable) in the 232's web admin and enabled it.  After doing a firmware update the handsets picke...
c duff by Level 1
  • 377 Views
  • 0 replies
Does anyone have any experience with configuring the SPA 3102 with the Ooma Telo devise. I have been around and around on this with no luck. I have been able to get into my 3102 ip address fine, but I need a proxy server to configure the 3102 with my...
Hello, we have 10 users in our network and we have 4 FXO port and lines connected to them, we would like to implement this on UC540 below; 2 users will have access to FXO port 13 users will have access to FXO port 23 users will have access to FXO por...
rammany19 by Level 1
  • 329 Views
  • 0 replies
I have 2 x Cisco 7925G phones that are running 1.4.1 SR1.  If I upgrade the phones by USB to 1.4.5, will I run into any issues.  I can't upgrade the firmware through the UC520 since its newer than the software pack.  I guess the same question would a...
ReidJones by Level 1
  • 1470 Views
  • 7 replies
I've been trying and trying to create a custom ringtone for my Cisco 303SPA but I haven't been able to!According to this FAQ the Cisco 303SPA ringtone format is G.726-32, and Ring Tone Suffix is .726. However when I try to create the ringtone, it doe...
Santicity by Level 1
  • 686 Views
  • 0 replies
