Wireless
review
Labels
Hi,I've read the various threads about Azure's default behaviour of dropping fragmented UDP packets and I have an open support call with MS and enable-udp-fragment-reordering has been set on my subscription.I have a WLC and NPS in UK South and the sa...
tomab by • Frequent Visitor
  • 173 Views
  • 5 replies
Hi does anyone know if there is an official Cisco statement re any co-axle low loss cable length limitation when connecting legacy AIR-ANT type antenna via the AIR-CAB002-D8-R= cable for use with 9174E APs? Or are we into using the transmission power...
sbcoms by • Community Member
  • 135 Views
  • 1 replies
HI I have a customer asking why Cisco does not manufacture an extension cable for use between native DART-8 APs such as the 9174e and native DART-8 Octal Dart antenna such as the C-ANT9102 of more than 3m i.e. the AIR-CAB003-D8-D8=.Can I assume this ...
  • 237 Views
  • 2 replies
Current setup:WLC 9800-L-F-K9 (Active) → Core Switch (Primary) → Active Gateway → FTD Firewall → Router → ISPWe have purchased another WLC 9800-L-F-K9 and need to configure High Availability (HA) between the two controllers.The new WLC will act as St...
zhd27 by • Level 3
  • 1484 Views
  • 5 replies
Hello, colleagues! I deployed the WLC 9800 on ESXi, transferred the access point 9105AXI to a lightweight one with the command "ap-type capwap".But then a problem arose: the access point receives its IP from DHCP (15 VLAN), the controller sees it, bu...
burich96 by • Spotlight
  • 24863 Views
  • 6 replies
A Plan's afoot to change the name of my wlc stacks.  My guess is while the CLI execution is effortless, I don't think the system will update all the Primary controller names but since the AP does an ip relink or a DNS call out to Cisco Capwap Control...
