Wireless
review
Labels
Please advise and give me your opinion:I need to perform a ROMMON upgrade from version 17.7(3r) to 17.12(1r) on a C9800-40. The guides say that I must use the command reload and not reload slot x, which means both WLCs will restart, not just the one ...
Do I need the http gui turned on to have sensors functional on the switches? Seems the web gui typically has vulnerabilities/patches historically. I’d love to run the sensors without having to worry about it.
nielfokert by • Community Member
  • 188 Views
  • 1 replies
Meraki, why does the "show AP name in beacon" option not appear under the Wireless>Configuration>Access Control Dashboard Page? The SSID is WPA 2 Enterprise, all APs are MR36 running MR 32.2.4 code. The AI Deep reasoning says there should not be an i...
sbcoms by • Community Member
  • 204 Views
  • 1 replies
Hi, during the process of C9800 software upgrade from 17.9.6 to 17.12.8 , AP image predownload are stuck since 5 days. Does anyone knows how to cancel the AP image predownload. Also as you see in the picture below many APs failed to predownload, any ...
bouazzaoui by • Community Member
  • 361 Views
  • 6 replies
Hey cisconians,Just wanted to know if cisco provides access to coding tools like claude, codex?Or do they have any internal ai that is given to the employees?I recently heard that oracle gave unlimited codex for its employees.
Hi ,Who is currently using the new Assurance Experience Metrics in Meraki ? https://documentation.meraki.com/Platform_Management/Dashboard_Administration/Operate_and_Maintain/Monitoring_and_Reporting/Meraki_Assurance_Overview_PageI'm running MR32.2.5...
Raphael_L by • Meraki Community All-Star
  • 698 Views
  • 9 replies
From an airtime utilization perspective, I want to understand the impact of SSID design.Currently, I have:2 SSIDs configured as 5 GHz-only4 SSIDs configured as 2.4 GHz-onlyDoes this design reduce 5 GHz airtime utilization compared to having all SSIDs...
HI,We are experiencing a significant wireless connectivity issue following a recent migration from Cisco Aironet 1850 Access Points to the new Cisco CW9172I Access Points.Environment:Wireless Controller: Cisco Catalyst 9800 WLCPrevious AP Model: Cisc...
shlomoi by • Level 5
  • 430 Views
  • 5 replies
Hello team,I'm trying to figure out the licensing around migrating some legacy APs from a 5520 to a CW9800L.  We have 3802 APs on the 5520 now, and want to move them to the 9800s as part of a phased migration that will eventually end with the 3802s b...
Lance M by • Frequent Visitor
  • 346 Views
  • 3 replies
