Finesse agents suffering from AutomaticTabDiscarding Chrome feature
Hello all,
We have a Contact Center Express deployment 11.6(2) and the agents use Finesse on Chrome.
Our reporting team noticed in the "Agent State Detail Report" that many agents are frequently getting Logged out with the cause "Connection Failure". Now Cisco documentation tells that some possible causes are "Finesse tab closed" or "browser crashed".
Digging further on this issue we found out that during an active call (the agent is going back and forth through the CRM, the Ticketing, the Monitoring portals etc.) and after a while (few minutes or so), when the agent returns back to Finesse tab, the tab immediately refreshes like if he's logging in freshly.
After some troubleshooting, it seems that when the RAM of the Agent PC gets low, Chrome kicks in a new feature called Automatic Tab Discarding, which is basically killing the Finesse tab...
This feature can be disabled in Chrome through chrome://flags, or I can selectively prevent the Finesse tab from being discarded in chrome://discards/ (but the latter is not persistant i.e. when we close the Finesse tab and reopen it, we have to prevent it from being discarded again...)
The problem is that there's no way to implement an enterprise-wide solution (as far as Google documentation is concerned) to disable this *catastrophic* feature causing outage for Finesse when many tabs are opened in Chrome.
Our supervisors are using the "Agent State Detail Report" in order to count the "Not Ready - Coffee Pause" that each agent took, however, when the 'Logged-out Connection Failure" kicks in, the count of Not Ready stops. (ie the agent put himself Not Ready and goes for a 10-minute pause before returning to Ready state, and the logout Connection Failure appears after 3 minutes, then the Not Ready State stops after 3 minutes)
Do you guys face this issue ? How are you dealing with it ? Is there a way to implement an enterprise-wide solution (GPO for example) for it ?
Thank you for your inputs.
38 Replies 38
That's the thing, it wasn't even a full auto update, check it out. Kind of scary.
https://www.zdnet.com/article/google-chrome-experiment-crashes-browser-tabs-impacts-companies-worldwide/
Noob question. So instead of letting Agents login through web browser, why cant we do IP Phone agent and let our agents login through the phone?
You can. Why do you think you cannot? It's called Finesse IP Phone Agent.
Just an update from the past few months. Some of our users started seeing a large amount of issues with Finesse 50002 errors and constantly failing over from Finesse A to Finesse B.
One thing that has helped improve this issue is having Finesse open in its own window in Chrome and also to never minimize this window. This seems to avoid any discarding or throttling that chrome does. This might not work for every group in our company but provides some relief.
A Cisco TAC engineer told me to try launching Chrome with the option --disable-background-timer-throttling to avoid the tab discarding with the Finesse tab.  Has anyone tried this suggestion?
Yes, a user at the bottom of the first page of this thread did and said it didn't resolve their issue.
BalajiSivaraj49175
Chrome 67 and later do not show Live Data reports.
There is a specific Cisco cop file to fix that
UCCX-Chrome-67-ET-COP.zip
I don't know anyone running email/chat in Chrome
a6z69@yahoo.com
We faced same issue, Solve it by the below steps:-
Step 1: Open a new tab, type chrome://flags, and then press Enter. Next, type Tab Discarding into the search box to bring up the #automatic-tab-discarding flag.
Step 2: Select Disabled from the drop-down menu next to the flag and click Relaunch Now. Chrome should restart automatically to apply the change.
piyush aghera
We also faced this issue with Chrome, but its random (another headache). Solution given to us by TAC was to use Edge in IE mode which will work as normal IE and will not have any of these newer features. It does help with most of the agents.
Piyush Aghera
BLOG
