Call Forward Call manager
Laurel McDargh
In Call Manager, I set a phone to forward to another phone. However, when I test it, it is not forwarding. Is there a service that might need restarted or are there some more basic elements I might need to check?
9 Replies 9
Jaime Valencia
No, thats it. Make sure the change shows in CCMadmin, and also that replication is working fine
java
if this helps, please rate
Chris Deren
In addition ensure the forwarding CSSes are setup properly with access to the forwarded destination.
Chris
Gordon Ross
Level 9
Level 9
In addition to Jamie & Chris' answers, check that you're setting the right CallForward!
GTG
Please rate all helpful posts.
In addition to what Jaime, Chris and Gordon suggested, check the calling search space activation policy value which by default is with configured css
Carlo
Please rate all helpful posts "The more you help the more you learn"
Apart from what all the genious suggested, check by dialing the same number from the same phone who is forwarding.
Also what error you are getting while call fails?
Are you trying to forward the call internally or to external destination?
Nishant Savalia
Regards, Nishant Savalia
mohamed helmy
Hello Laurel,
Also please check if this extension used in a hunt group, cause it won't work
Mohamed Helmy
Regards, Mohamed Helmy
Laurel McDargh
When I went into work I could see that the extension is actually forwarding, but it returns to the forwarded phone'a voicemail which we don't want. We would like it so that callers can leave a message on the extension where the phone is forwarded. But I don't know if that is an option. CSS is set correctly. Is there something in Unity that might take care of the issue? I am not getting any errors
Thank you for all responses!!
Hi Laurel,
is it a unity connection installation ?
Are the unity connection configure via SIP or SCCP ?
If SIP is configure look into the SIP Trunk
Stefan
Rob Huffman
Hi Laurel,
+5 to all my friends here
You can have a look into this "System-wide" setting which is available in Unity Connection 7.x & later ;
Via
Cisco Unity Connection Administration
Advanced (towards the bottom of the page)
Conversation Configuration
**Use Last (Rather than First) Redirecting Number for Routing Incoming Call**
You would need to think about what impact this might have on your overall setup, but it does allow
for users to Forward to their personal VM at times and to achieve your secondary requirement as well
Cheers!
Rob
"May your heart always be joyful
And may your song always be sung
May you stay forever young "
- Dylan
