H323 Bind issues
Kaushik Ray
(config-subif)#h323-gateway voip bind srcaddr xxx.xxx.xxx.xxx
Bind IP Address configured. Please remove before reconfiguring
I am getting this message despite no bind address configured. anyone seen this issues before?
RTR#sh run   | include bind
RTR#
Any advise will be much appreciated.
18 Replies 18
Chintan Gajjar
Level 8
Level 8
yes, if you alredy did bind this interface with src adress previously.
please use
no h323-gateway voip bind src
and then try to issue the command
also you can see thebinding in sh run and will show where interface is alredy bind.
regards
Chintan
that is the issue, i cannot see any bind existing on the router
Hi Ray,
can u cross-check in show startup config?
regds,
aman
RTR#sh startup-config | include bind
RTR#
no :(
try the below
RTR#sh startup-config | include h323-gateway
RTR#
Give the router a reload and that should solve this for you.
Please rate all useful posts
hi,
the command will be invisible after you have changed the interface ip address.
you just issue a " no h323-gateway voip bind srcaddr " on the interface then should you should be able to execute the new binding with no problem. no need reboot.
if you have access to router on console, try doing default interace
only have remote access :(
Hello
1- if you did not find a solution , but be patient many suggestions from expert people will come . You can follow the following Mr/Aman solution , or do a backup for the configuration and then do # write erase and add your configuration again , but of them it should be using Console .
thanks
please rate al useful information
Hello
Can you check all the configurstion , after display sh run?. There is a bind command already existing , check under loopback, voice vlan. interfaces . Share your "sh run".
please rate all useful infromation
version 15.0
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime localtime show-timezone
service password-encryption
service compress-config
hostname RTR
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.150-1.M4.bin
boot-end-marker
card type e1 0 1
logging buffered 4096
aaa new-model
aaa session-id common
network-clock-participate wic 1
no ipv6 cef
no ip source-route
ip cef
ip vrf 3RD_PARTY
 rd
 route-target export
 route-target import
ip vrf DATA
 rd
 route-target export
 route-target import
ip vrf forwarding
no ip dhcp use vrf connected
no ip dhcp conflict logging
ip dhcp excluded-address 172.27.165.1 172.27.165.25
ip dhcp excluded-address 172.27.165.129
ip dhcp pool VLAN1
   network 172.27.165.0 255.255.255.192
   dns-server xxx.xxx.xxx.xxx
   default-router 172.27.165.1
   option 150 ip XXX.XXX.XXX
   lease 3
ip dhcp pool VLAN133
   network 172.27.165.128 255.255.255.192
   default-router 172.27.165.129
   lease 0 3
no ip domain lookup
isdn switch-type primary-net5
voice-card 0
voice rtp send-recv
voice service voip
 fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
 modem passthrough nse codec g711ulaw
voice class codec 1
 codec preference 1 g729r8
 codec preference 2 g711ulaw
voice class h323 1
  h225 timeout tcp establish 3
  call start fast
voice translation-rule 100
 rule 1 /^.*/ /xxxxxxxxx/
voice translation-profile MAPOUTSIDE
 translate calling 100
hw-module pvdm 0/0
redundancy
controller E1 0/1/0
 line-termination 75-ohm
 pri-group timeslots 1-31
 description ### PABX ###
controller E1 0/1/1
interface GigabitEthernet0/0
 description ### Trunk  ###
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/0.1
 description ### Managment, Server and Voice network ###
 encapsulation dot1Q 1 native
 ip address 192.168.1.1 255.255.255.0 secondary
 ip address 172.27.165.1 255.255.255.192
 no ip redirects
interface GigabitEthernet0/0.2
 description ### Lan ###
 encapsulation dot1Q 800
 ip vrf forwarding DATA
 no ip redirects
 ip tcp adjust-mss 1400
 bridge-group 2
 bridge-group 2 input-address-list 702
interface GigabitEthernet0/0.5
 description ### Riverbed AUX Port ###
 encapsulation dot1Q 5
 no ip redirects
 ip nat outside
 ip virtual-reassembly
interface GigabitEthernet0/0.133
 description ### Internet Wifi ###
 encapsulation dot1Q 133
 ip vrf forwarding 3RD_PARTY
 no ip redirects
 ip accounting output-packets
 bridge-group 33
 bridge-group 33 input-address-list 733
 bridge-group 33 output-address-list 733
interface GigabitEthernet0/1
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/2.950
  bandwidth 1024
 encapsulation dot1Q 950
 ip address 172.27.165.254 255.255.255.252
 ip flow ingress
 ip flow egress
interface GigabitEthernet0/2.951
  bandwidth 768
 encapsulation dot1Q 951
 ip address 172.27.165.250 255.255.255.252
 ip flow ingress
 ip flow egress
 rate-limit output 768000 8000 8000 conform-action transmit exceed-action drop
interface GigabitEthernet0/2.952
 bandwidth 256
 encapsulation dot1Q 952
 ip address 172.27.165.246 255.255.255.252
 ip flow ingress
 ip flow egress
 rate-limit output 256000 8000 8000 conform-action transmit exceed-action drop
interface GigabitEthernet0/2.959
 encapsulation dot1Q 959 native
 ip address 172.27.165.242 255.255.255.252
 ip flow ingress
 ip flow egress
interface Serial0/0/0
 bandwidth 1024
 no ip address
 encapsulation frame-relay
 load-interval 30
 no keepalive
 priority-group 1
 ignore dcd
 no clock rate 2000000
interface Serial0/0/1
 no ip address
 shutdown
 clock rate 2000000
interface Serial0/1/0:15
 no ip address
 encapsulation hdlc
 isdn timer T310 120000
 isdn protocol-emulate network
 isdn incoming-voice voice
 no cdp enable
interface BVI2
 ip address 172.16.199.1 255.255.255.0
 no ip redirects
 ip nbar protocol-discovery
interface BVI33
 ip address 172.27.165.129 255.255.255.192
ip forward-protocol nd
no ip http server
no ip http secure-server
ip flow-top-talkers
 top 20
 sort-by bytes
 cache-timeout 30000
ip nat inside source list 150 interface GigabitEthernet0/0.5 overload
ip route 0.0.0.0 0.0.0.0 172.27.165.253 name default
ip route vrf 3RD_PARTY 0.0.0.0 0.0.0.0 172.27.165.245 name Default
ip route vrf DATA 0.0.0.0 0.0.0.0 172.27.165.249 name Default
control-plane
bridge 2 protocol ieee
bridge 2 route ip
bridge 33 protocol ieee
bridge 33 route ip
no call rsvp-sync
voice-port 0/1/0:15
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
dial-peer voice 100 pots
 destination-pattern XXXXXXXX
 port 0/1/0:15
 forward-digits all
dial-peer voice 2000 voip
 preference 2
 destination-pattern .T
 progress_ind setup enable 3
 session target ipv4:xxx.xxx.xxx.xxx
 voice-class codec 1
 voice-class h323 1
 dtmf-relay h245-alphanumeric
 playout-delay nominal 130
 playout-delay mode fixed
 fax-relay ecm disable
 fax rate 9600
 clid network-number XXXXXXXX
 no vad
dial-peer voice 2001 voip
 preference 1
 voice-class codec 1
 voice-class h323 1
 fax rate 9600
 no vad
can you try negate command and then try to issue command once agian.
also on your router, if you issue below commanad whta output it gives?
sh run |  s bind
ther will be binding defined somewhere
regards
Chintan
