Urgent*Forced Authorization Codes Fails using VG224 with SCCP
Hello Everyone,
Please I would ask you help to resolve an issue with the Analog VG224.
I`m implementing IPT in a site witch uses FAC codes to dial out.
Using it with IP phones witch are 20% of the overall phones,it works fine, however when trying to dial out using the analog extension of the VG224, the system does not ask for the FAC and the call fails.
Removing de FAC from the route it completes the call normally.
Does anyone has a clue why the analog is not receiving the beep to insert the code and call is failling?
Here is my config :
Thanks in advance
Thiago
Current configuration : 3210 bytes
! Last configuration change at 01:24:03 UTC Mon Mar 1 1993
version 15.1
no service pad
hostname BRBSOAVG01
boot-start-marker
boot-end-marker
enable secret 5 $1$ZqSc$8yV3huooMh5A4tmyIkcqJ.
no aaa new-model
ip source-route
ip cef
no ip dhcp use vrf connected
no ipv6 cef
stcapp ccm-group 1
stcapp
stcapp feature access-code
prefix #
stcapp supplementary-services
port 2/0
  fallback-dn 313202
voice service voip
modem passthrough nse codec g711ulaw
voice-card 0
interface FastEthernet0/0
ip address 10.98.48.6 255.255.254.0
duplex full
speed 100
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
ip route 0.0.0.0 0.0.0.0 10.98.48.1
control-plane
voice-port 2/0
cptone BR
voice-port 2/1
cptone BR
voice-port 2/2
cptone BR
voice-port 2/3
cptone BR
voice-port 2/4
cptone BR
voice-port 2/5
cptone BR
voice-port 2/6
cptone BR
voice-port 2/7
cptone BR
voice-port 2/8
cptone BR
voice-port 2/9
cptone BR
voice-port 2/10
cptone BR
voice-port 2/11
cptone BR
voice-port 2/12
cptone BR
voice-port 2/13
cptone BR
voice-port 2/14
cptone BR
voice-port 2/15
cptone BR
voice-port 2/16
cptone BR
voice-port 2/17
cptone BR
voice-port 2/18
cptone BR
voice-port 2/19
cptone BR
voice-port 2/20
cptone BR
voice-port 2/21
cptone BR
voice-port 2/22
cptone BR
voice-port 2/23
cptone BR
ccm-manager sccp local FastEthernet0/0
mgcp profile default
sccp ccm 10.96.32.4 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
bind interface FastEthernet0/0
associate ccm 1 priority 1
dial-peer voice 1 pots
service stcapp
fax rate disable
port 2/0
5 Replies 5
dferrat
Hi ,
I have the same problem anyone has found a solution?
I seem to be running into the same issue, my understanding is that forced authorization codes are supported with SCCP, though they do not seem to work, IOS 15.1.4M6.
Chris
FAC for Analog phones behind VG gateway can be supported using a 3rd party application.
Users experiance:
  • User dials the outbound number
  • 3rd party application is invoked(IVR) and user is prompted to enter his FAC code
  • FAC code is authenticated
  • Call gets dialed out
One of our customers had SIP phones and faced the same issue of support for FAC.We solved the issue using a 3rd party application.
Hi Pranjol,
I was going through the post, we are under same problem that FAC is not working with VG350, although it was working earlier.
You mentioned that it works with third party application, can you please let me know which Third party application assist to make FAC work with Cisco CUCM.
Navinder Singh
yoshio.homma
I had the same issue and tried to dial the FAC + #  after dialing the destination number and it works, the problem is just that it never plays the beep asking for the code.
