MPLS
Hi Following "Another Discussion " i have this problem which the output of "show mpls forwarding-table exact-route" is not correct.i tested it on both ASR903(15.6(2)SP) and CSR1000V(15.4(3)S)this is the output of my csr1000vit says that its going to ...
Could you please tell me when will be the Cisco C1111-4P router be EoL?   Currently we have issues with some countries not letting the device to be installed and I would like to know if there will be an EoL announced in the next years.
We have a simple l2vpn xconnect between a new NCS-57C3 and an existing ASR-9906 via 100G link in a single rack.  We have JDSU 5800 test units attached to both ends on 10G ports.  We have a customer requesting that their RFC2544 test be able to pass 7...
pboehmer by Level 1
  • 552 Views
  • 4 replies
Hello,                         R7                      /        \R1---R2--R3--R4--R5 ----r6                     \.        /                        R8On R3R3#show mpls forwarding-table 6.6.6.6Local        Outgoing         Prefix                     By...
I am studying for the CCNP ISPCORE and i am configuring EVPN. I have configured EVPN so far with no problems but can't seem to make it work when one of the sites is using vpls. Many documents and presentations say there is interoperability, but I hav...
emurray by Level 1
  • 404 Views
  • 3 replies
  • 1 Helpful votes
Working on the following topology.MPLS TE Tunnel on PE1 is successfuly configured.but I cannot reach CustomerB from PE1. The control plane information seems to be ok but I am not sure if the data plane is broken.  Any help is appreciated.
zeeshanbasit25789_0-1751536148148.png zeeshanbasit25789_1-1751536198443.png zeeshanbasit25789_2-1751536224280.png zeeshanbasit25789_3-1751536305751.png
%BGP-4-VPN_NH_IF: Nexthop :: may not be reachable from neigbor 1.1.1.1 - not a loopbackWe have an InterAS option  B  scenario where we receive this log entry. my question is how i can interpret this entry (we receive it on an ASR1002X (R2), 1.1.1.1 i...
Hello community,    Does the Nexus 93180 support the segment routing mapping client? Could you give me a hint? I can't get the prefix sid from the segment routing mapping server (
config by Level 1
  • 427 Views
  • 4 replies
Top Solution Authors
