Network Management
Insider User Research program
Don't miss this Cisco Catalyst 8000 offer
Labels
Hello, i still asking about how the network send the data to internet looks like. Can anyone help to explain.Every data we send to the internet will always pass through the ISP, which means the ISP can know the destination (and perhaps the contents o...
vov by Level 1
  • 145 Views
  • 4 replies
I have an 8000-series router running IOS XR.  I need SNMPv2 to work, but by default that enables SNMPv3.  I need to explicitely disable SNMPv3 without disabling SNMPv2.ACLs don't seem to work on the SNMPv2 configuration line.  ACL'ing the physical in...
Hi Everyone,I'm interested in streaming telemetry using GRPC to our organization's ELK environment.Can you share with me the recommended GRPC Collector - I saw a couple of solutions such as1. Pipeline2. Telegraf3. pmacct4. nifiI appreciate any help y...
MosheIT by Level 1
  • 462 Views
  • 2 replies
Hello Everyone,I'm novice to networking. And below is the requirement I'm trying to figure out. Any leads would be greatly appreciated"You are working as an IT architect for a new startup business that grew faster than expected. they expanded to oper...
Ram253 by Level 1
  • 384 Views
  • 6 replies
Hi,I have a simple EEM applet which triggers a syslog message whenever anyone enters enable mode (to be exactly it triggers a syslog message whenever anyone types ena on the cli, so if anyone knows a better way to do it, I would be glad to know how)....
kb70 by Level 1
  • 1478 Views
  • 9 replies
Hi everyone,To all engineers who love cisco CLI, what is the possible solution to this below errorKey exchange failed.No compatible MAC. The server supports these MACs: hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha2-256,hmac-sh...
amutua17 by Level 1
  • 1826 Views
  • 3 replies
At my new job, I was told RADIUS hasn't functioned for over a year.  I wiped the RADIUS server settings and started from scratch.  I'm happy to say, after going thru every cisco device, ALMOST all devices now login via RADIUS flawlessly.  There are t...
Marcus023 by Level 1
  • 349 Views
  • 4 replies
Hi I have a EEM script where I use the '$_cli_result' command to display it in the output. I'm not entirely sure if this would be saving to the flash and then the $_cli_result command is pulling from there. I don't think it would save to flash but I'...
Sunny5 by Level 1
  • 153 Views
  • 4 replies
