What is the criteria to create SVI and VLANs in the 9800. If you take multiple AP management bands (vlan) to the same network Do I have to need several SVI and/or Vlans?
The content you are looking for has been archived. View related content below.
Hello.On the Software Update page of Prime there is one Pack which i can not install or delete because it is already included in another installation i did before. Now this pack stays on the page and i am not able to remove it. Does anybody know wher...
I've got 15+ Cisco ISR 4000's (a mix of 4331s and 4551s) in our network and when trying to setup Netflow to PRTG, It seems that when I hit 5 interfaces that need to be monitored, there is always 1 that won't come up in PRTG and that doesn't send data...
My network endpoints use the IP addressed vlans on my core cisco layer three core switch as their gateway addresses. i.e.- vlan 11 endpoint address 192.168.11.3/24 with gateway 192.168.11.1/24 (vlan ip on core) and vlan 12 endpoint address 192.168.12...
I am trying to measure a link speed I have a traffic generator machine.I want my Cisco ASR-1001 to loopback the traffic to the generator,What config do I need to use?I am trying to do it in Layer 3 and there is a switch in between.
Hi all. I'm new to networking and inherited a Ring topology network that was never connected at one box to complete the ring. It is made up of an LC Fiber ring of all Cisco 3750X switches all set up on the same VLAN. I am in no position to change the...
For Cisco WS-C9200L-24T-4G-E, a user tried to backup configuration from Web portal. But did wrongly that uploaded empty text file to the device.That is:Copy to devicetftpaaa.txt (created from local computer)startup-configupload to device.Now the star...
Dear all,I am configuring a network cfomposed of 4 VLANs with the following devices:- NetGate 6100 Firewall- A Cisco 2951 Router- Ciscon 2960 SwitchVLANs and DHCP were configured on the 2951 router.Note that NAT function is handled by the Firewall.Af...
You want to use ISE to set up TACACS on Nokia 7750 SR, does it work?
Hi All!I am currently deploying NAC in my organisation's switches and was wondering if there is a Python script to help ease this task.The commands are almost the same on all the ports, except for the dot1x/mab priority one when there's a device conn...
Hello,The DISA STIG, V-239941, asks that the following be configured:event manager applet BACKUP_CONFIG event syslog pattern "SYSLOG_CONFIG_I" action 1 cli command "copy startup-config scp://userx:xxxxxxx@10.1.48.10//opt/config_backup" action 2 syslo...
I have a exanic x25 I wanted to know how and from where can we increase this size of the tx buffer. Any help or suggestio?
Hello,I upgraded our On-Prem server from Release 8-202201 to 8-202206. After the upgrade I'm not able to login to the GUI. We used TACACS+ (ISE) to authenticate. Also the local admin user is not working: "The requested user is not found".From the CLI...
Hello,i have a pc connected to VPC Peer Switch (vPC2) which has the secondary role. vPC2 builts a vPC with vPC1. How can i configure the port to always keep up the connection for this device, even when peer-link goes down (dragging out the cables).In...
I have upgraded cisco NCS-5504 router . Router was successfully upgraded but all the line cards are not showing. In platform command type is unknown and state is SW_Inactive.Regards Salman
Subject | Author | Posted |
04-26-2024 01:01 AM | ||
04-23-2024 05:52 PM | ||
04-23-2024 12:20 AM | ||
04-16-2024 04:45 AM | ||
04-16-2024 01:33 AM |
User | Count |
3 | |
2 | |
2 | |
2 | |
1 |
