I'll rate every post that helps So, I've tryed the methods below to send the Break Signal to the Router in order to enter ROMmon and they aren't working Putty - CTRL+ Pause (Only the Pause key is available) - Right-Click> Special Command>...
The content you are looking for has been archived. View related content below.
Hi,I have deployed Cisco ASA Firewall in Azure and I am trying to configure the routes from Inside subnet to Internet. However, there is a default route to 0.0.0.0 on Management interface and it is conflicting with new routes I am trying to create. I...
Looking for some clarification regarding the capabilities of the ISR 4451, running IOS 17.0.9 since I can't find any documentation:Can the device run MLPP functions without the CME license? The ISR is in between an SS7/T1 to E1 converter and an encr...
Hello,I am trying to configure SNMP access to NeDi on a Catalyst 9300 Switch. This is the current status:Nedi:Created the "nedimon" community string. (SNMP v2c)C9300:snmp-server community nedimon RO IPv4-RO-SNMP-LOCALStandard IP access list IPv4-RO-S...
Hi, if I have remove a client using Cisco Prime Infrastructure how do I re-enable or allow it back in to the network.
Hi: I trying to monitor OSPF in multiple VRFs. I have created multiple context in SNMP. Here is what my config looks like:snmp-server context default vrf defaultsnmp-server context abc01 vrf abc01snmp-server context abc02 vrf abc02snmp-server communi...
Hi,With stateful ASA FW pairs you configure interfaces with primary and standby IPs.Must standby IPs necessarily be within the same LAN as primaries?If so, must they be within the same VLAN? Or can routing be used to interconnect them instead?For MGT...
I have created a vpn tunnel between the asa firewall (ikev1) and the cisco router. the asa subnet is 192.168.100.0/24, the router subnet is 10.100.0.0/24. The VPN works fine and they can communicate with each other. But I can't NAT the 192.168.100.0/...
I have been stuck at this assignment for a week now. No matter what I try even redoing the whole thing serveral time, I can't seem to figure out why the DHCP server is not working for the PCs. I would really truly appreciate if you can help me find o...
Hi everyone,To all engineers who love cisco CLI, what is the possible solution to this below errorKey exchange failed.No compatible MAC. The server supports these MACs: hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha2-256,hmac-sh...
Good day,I require some Assistance.I have Configured Radius Authentication on all of our Cisco Switches, but I have Randomized Issues that I am not sure how to fix. The Authentication works 100% on our Domain computers.With some computers we have a I...
Good morning, requiring some assistance for bulk loading conference spaces on my CMS 1000 server. I am currently running the VM application Meeting server v3.0 on a CISCO UCS-c220-m5 server. I can build individual spaces and passcodes, and while th...
I have an ISR4321 router and a 2960x switch. I setup a super basic config, with DHCP. My laptop never gets an IP address. Static works fine to get to the internet.ISR4321/K9 running 16.09.04!hostname Test-Routerip name-server 8.8.8.8 1.1.1.1ip dhcp e...
Hi. I couldn't find in PI how to view a list of all interfaces on all switches at what speeds they actually work with automatic speed adjustment on the port (10/100/1000)?Not 5/10/15 switches, as on dashboards, but fromall switches on the network. an...
Hello,I am trying to upgrade Cisco Prime from version 3.8 to 3.10, but my CLI access is denied. The web access is working fine, but I canot Access the CLI using tools like PuTTY, for example. Could you please assist me in resolving this issue?Thank y...
Subject | Author | Posted |
09-19-2024 08:55 AM | ||
09-18-2024 05:45 AM | ||
08-21-2024 03:45 AM | ||
08-18-2024 09:11 AM | ||
08-16-2024 07:00 AM |
User | Count |
2 | |
2 | |
2 | |
1 | |
1 |
