Does cisco have a tool to automate the database backup process for the ONS 15454?
Hi,can anyone tell me if these two a compatible, the supervisor on 4503 is Supervisor Engine II-Plus-TS 12 10/100/1000 Mbit POE+ plus 8 SFPI've found in the documentation that the supervisor is compatible with GLC-SC-MM-Gigabit Ethernet SFP, LC conne...
I am looking for cbt or knowlegeNet like traning video for the ONS 15454? Is such available? I am happy to pay :)Francisco.
We are having an issue where we are not getting ARP replys from a device connected (172.168.48.48) to an ML card in the field. We have a switch connected to the ML card at the end head. There are 2 VLANs on the switch each with a gateway address, VLA...
We just finished an episode with our ONS15454 box having a bad OS-12 card. My question is this.Is there any way to Monitor this appliance so that we can detect when there are errors on the Card(s) or Management engine.
The traps cisco ONS is sending to HP Openview, some of the OID's are missing! and i noticed that HP openview cannot interpret the traps properly. Has anyone come across this problem before?
I am getting SNMP traps from our Cisco Cerent ONS 15454 . See belowGeneric: 6; Specific: 5120; Enterprise: .1.3.6.1.4.1.3607.6.10.30;Variables:[1] private.enterprises.cerent.cerentProducts.cerent454Mib.cerentCommonObjects.cerent454CommonObjectsGroup....
I would like to have information about a CISCO switch which can support fiber ports SFP(1g) and SFP+(10g) and copper 1g and 10g ethernet ports. And will it also software upgradable to support L3 protocols ?
I have a router with the following interfaces : interface FastEthernet6/0 description <<137.55.67.0 Subnet>> ip address 137.55.67.1 255.255.255.0 ip access-group 100 out duplex auto speed auto!interface FastEthernet6/1 description <<137.55.68.0 Subne...
I have a WS-C3550-24-FX-SMI fiber switch and it was being used on a 62.5 Micron fiber infrastructure. The office moved to a new facility that has a 50 Micron fiber infrastruture. Can I still use the same switch and what problems will their be if I ...
Hi All, We are trying to log the no.of hits for a permit ACL statement ,which is applied to an interface on a ML100 card but couldn't see any hits.So we are tring to capture the port traffic and send to a port where a sniffer is connected but couldn...
Hi all,someone knows about new Cisco optical certification with integration of all new feature like NG-SDH and service handling EVPL etc etc, and of course, some books for studiyngthxDanilo
HiI need to seup a dwdm with a psm card and 3 mxp_2.5g cards connected to a shelf holding cwdm and ewdm units.i have a problem configuring the internal patchholders so it will point to the ewdm shelf.
HiBased on the data sheet of a 10GB SR port, there is a sentence that read: The launch power shall be the lesser of the class 1 safety limit or the maximum receive power. Class 1 laser requirements are defined by IEC 60825-1: 2001.So the question is...
Hi Guys,Can the below setup work?WS-C2960-48TT-L (Gigabit uplink) ---- Cat 5 Lan cable --- Media converter 10/100 --- Multimode fiber < 50 meters ---- GLC-SX-MM= --- CE500G-12TCPlease advise, thanks.
Subject | Author | Posted |
10-04-2024 12:50 PM | ||
09-24-2024 09:19 PM | ||
07-25-2024 01:25 PM | ||
05-05-2024 05:19 AM | ||
03-27-2024 12:16 AM |
