Routing
Labels
I have router a with a gre tunnel (tunn 1)to router b. Gig 0/0/0 to Gig 0/0/0i need to make another tunnel from A to a third on router C. C is connected to B on gig 0/0/1. No routing protocols it’s a small network all static’s. What’s the best way to...
ColForbin by Level 1
  • 312 Views
  • 10 replies
Hello Experts , I have a critical application traffic which passing though my Cisco ISR 4321 and i noticed that some packets being dropped as Taildrop , Please find below output from packet-trace debug :    sh platform packet-trace summary | i Gi0/0/...
qsosan20 by Level 1
  • 511 Views
  • 16 replies
  • 1 Helpful votes
Hi AllI have a lab setup using DMVPN phase 3 with eigrp, a hub and 2 spokes.If I shut down the hub external IP, the spoke to spoke traffic fails within a few seconds.Is this normal? I know for redundancy you can have 2 hubs but would it still affect ...
Hi there,I am using packet tracer and I have an issue with area A talking to area B or area B to area ACloud is configured to use modem4 to Ethernet6Server has DHCP on and can talk to router and other PC in area A but not area BArea A inside IP is: 1...
maxintime by Level 1
  • 273 Views
  • 7 replies
Hi Guys,  I know that the MOD80 LC is old and EOL but just wanted to double check if it can be working with ASR 9904 chassis. it is kind of an urgent router that must be deployed in one of the customer location and the customer has A9K-MOD80-TR and A...
Hi All, I have IP SEC tunnel from hsrp peer1 and dna advantage license activated on it and peer2 activated with right to use (RTU).Ill setup IP sla from peer2 towards peer 1 and will be tracked by EEPM applet.If Peer 1 goes down, then EEPM applet wil...
Please refer to the picture I added. I have a situation where in ZONE1 and ZONE2 NEED to have the exact same IP address schemes. ZONE1 and ZONE2 connect to SW1 via point2point connections. The idea is that host connected to SW1 in the 10.0.0.1 need t...
mcast999 by Level 1
  • 240 Views
  • 3 replies
  • 1 Helpful votes
