Routing
Labels
How to change ip host con1* to ip host cv2*   ip host con1-0-8-ru19-p9 2106 10.76.4.100ip host con1-0-9-ru19-p10 2107 10.76.4.100ip host CV2NAFW01a 2122 10.76.4.100ip host CV2NAFW01b 2123 10.76.4.100
ialston by Level 1
  • 72 Views
  • 2 replies
Hi All, I am exploring the features of BGP Graceful Maintenance in IOS XR environment.I am facing difficulties to configure gshut community as I am not able to find any document for configuration guidelines for BGP graceful shutdown for IOS XR. When ...
Hi All, I have an ASR 903 that I am running 16.12.5 on and I only have logs showing that the port-channel has a member taken out and then added back. It is a two-port port-channel (20Gbps LAG). There is no min-links config on the port-channel.  Has a...
Hello All,I have two sites geographically separated and I am troubleshooting an issue with our sys admins. The provider of the service were having issues with said that multicast must been used between the 2 SVI subnets that each site has for our LFD...
Hi, We are using some old C881G-4G router with an LTE interface in remote location to gather data from sensors.Router has a two link types one is Ethernet and as backup we are using embedded LTE interface with a sim card an private APN and static IP ...
GregKK by Level 1
  • 158 Views
  • 3 replies
Hi there,I am using packet tracer and I have an issue with area A talking to area B or area B to area ACloud is configured to use modem4 to Ethernet6Server has DHCP on and can talk to router and other PC in area A but not area BArea A inside IP is: 1...
maxintime by Level 1
  • 724 Views
  • 16 replies
Hello there! From what I understand, the default-information originate should generate an OE2 default route only if there is already a default route in the routing table.My question is, Would it still generate a default route due to the default-infor...
rookie R by Level 1
  • 7252 Views
  • 10 replies
  • 1 Helpful votes
I am unable to launch Packet Tracer after downloading it from the academy On launch there is a Pop-up window that suggests that the app is unable to associate my net academy credentials and the tracer login. The result is that on closing this popup, ...
I’m just making sure on this. If you have two GRE tunnels whose source is the same interface, both MTU would still be 1476 correct?For instanceInterface gig 1/0/1ip addr 192.168.1.1 255.255.255.252tunnel 1ip mtu 1476ip tcp adjust-mss 1436tunnel sourc...
ColForbin by Level 1
  • 403 Views
  • 9 replies
