Routing
Labels
Hello I have a homeserver which is behind a CGNAT. Therefore, I use a VPS with public IP which is connected to my virtual opnsense via WireGuard to avoid this. This works perfectly, and I can route the traffic from the VPS directly to my VMs. But I h...
erverg by Level 1
  • 734 Views
  • 2 replies
I am attempting to leverage two ISR1100-4g routers to extend a subnet and vlan across a data center. This subnet hosts two Domain Controllers and my infrastructure team would like to host two new domain controllers in the same subnet in a different e...
Hi community,So i want to get some IBGP routes between two NXOS nodes, where one is running IGBP into the IGP (OSPF) onto the other node. This is to support a VM setup that the sever team claims has to come up on BGP and then be converted to our stan...
jbulloch by Level 1
  • 647 Views
  • 24 replies
  • 1 Helpful votes
We have global DMVPN Phase 2 network based on 4 hubs (2 in North America and 2 in Australia)Issue is related to Spoke nhs entries configuration order. Does it matter? If no how will nhs be choosen?Here is initial configuration of spoke in AUS:interfa...
I’m currently migrating from a Cisco Catalyst 3850 Layer 3 core switch to a Cisco Nexus N9K using vPC. On the Catalyst, Interface VLAN 1622 is configured with multiple IP addresses on a single SVI, as shown below:192.9.203.253192.9.209.253 secondary1...
gohcw by Level 1
  • 189 Views
  • 6 replies
We have kind of below setup.NW-1.0 <-- Router A <-> Firewall <-> Router B --> NW2.0There is ibgp neighborship between Router A & Router B and routers A & B are connected via firewall.Router A is advertising NW1.0 via ibgp nei to Router B, similarly R...
SandyYad by Level 1
  • 555 Views
  • 6 replies
Hi Team,Need help on bgp nexthop feature.I am trying to use bgp nexthop in ASR as well in nexus 9000 but it is not working. ASR -router bgp <>bgp nexthop route-map <> Nexus -router bgp <>address-family ipv4 unicastnexthop route-map <> Can someone ple...
Forward by Level 1
  • 101 Views
  • 2 replies
Good morningI have a cisco N540x switch, that the administrator password is corrupt or unknown.I have followed the following method, but it doesn't workhttps://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/ios-xr-software/217291-new-password-...
anas_id by Level 1
  • 3849 Views
  • 4 replies
I am running into an issue on cisco NCS (probably not an issue and is the intended behaviour)I have multiple /24s that are all used for a cloud cluster and the vm inside the cluster uses .1 of each /24 for gateway, so i have made a BVI and have added...
 PE1 has two vrfs configured CE1A and CE2A.Both CE1A (155.1.111.11/24) and CE2A (155.1.112.12/24) are advertising their loopback addresses.I am trying to leak the loopback of CE2A (150.1.112.12/32)  into CE1A without using the import route-target.I h...
