Does Firepower have the ability to setup and filter on policies that are based on words, numbers, etc...? Not content restriction or URL filtering. But a dirty word search and filter.
The content you are looking for has been archived. View related content below.
Currently my FTD is running version 7.0.4, I am thinking of upgrading to Release 7.2.8, can I upgrade to 7.2.8 at once or should I do it gradually?It is a Firepower 1120 managed by FMC version 7.2.4
Want to clear old faults from list presented on Overview screen in the GUI of a FPR-C9300?What are the commands from the command line? Thanks in advance.
This might be a dumb question but how would you set up the ASA firewall 1000 without internet connection? I have a switch that connects to it. I think I can console into it with putty but isnt there a gui ?
Hello,the question is in the title. Is it possible to use the ASA as a router between 2 internal networks? interface GigabitEthernet1/1nameif outsidesecurity-level 100ip address 10.0.1.254 255.255.255.0interface GigabitEthernet1/2nameif insidesecurit...
HiI have a single Firepower 1120 running ASA software which is currently in production and working fine. It has been decided to add a second 1120 and convert them into an HA pair running as active/standby for redundancy. Can anyone advise if there is...
I have a pair of FPR2130 running ASA code in HA. Everything looks configured OK to me, though obviously there's an issue somewhere! sho failover presents no errors.I need to failover to compete a firmware upgrade, however when via the primary device ...
If Mgmt1/1 interface is on another subnet, how can I put a different gw for that?(or something like a vrf)or it uses the default gw that I already setup on FX-OS?!lolbut what about 5555x that doesn't have FX-OS? Thanks,
Hi ,please I totaly confused about the EOL date of NGFW ASA5545-X series would you please confrim the date of EOS ,EOL it is not clear in cisco site
Hello!We have a Cisco ASA running version 9.18.4.22 that we are trying to do port forwarding on. Right now an endpoint hits the outside interface ip and should forward the traffic to one of our servers that sits on the inside interface. I had set thi...
Hello guys,So as we deploy (add) the Cisco FTD and FMC in VMware Workstation with the .ovf file, the default disk size is very less and since we can thin provision, how can I increase this size to 2 TB.Also, once I upgrade my Cisco FTD or FMC, does t...
Hi have exported a CA cert from my ASA and added to objects > PKI > cert enrollment. When added I then went to devices >certs and generated the CSR to be signed but the cert issued against the CSR has only hostname ‘firepower’ rather than FW-HOSTNAME...
I am attempting to migrate an ASA configuration to FTD and when I run the migration tool and the below selected the parsing fails. When I deselect RAVPN option the parsing is successful. What could be causing this?I have checked the licencing on the ...
We have an FMC ver 7.2 and recently was activate the passive authentication through the ISE. This is for begin to use the url and content filtering with the users. When we take a look at the collumn in the connection events we can see the URL informa...
It seems that ASA failover works fine without the standby address. What is the advantage of wasting an IP address?Regards,AM
Subject | Author | Posted |
09-19-2024 04:12 PM | ||
09-12-2024 08:37 PM | ||
08-30-2024 11:35 AM | ||
08-19-2024 03:53 AM | ||
08-14-2024 08:06 AM |
User | Count |
9 | |
7 | |
5 | |
5 | |
3 |
