Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board from June 18th - July 18th. These dates are subject to change pending progress. This in...
CoreyP319 by Cisco Employee
  • 584 Views
  • 0 replies
  • 1 Helpful votes
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5542 Views
  • 1 replies
  • 16 Helpful votes
Hi,Since a couple of weeks I have installed 5 SLM2024 Gig Smart Switches. Now we have a new Time Attendance System that tries to communicate to the Cisco with 10M. The Cisco identifies it correctly but will not parse any info to the Device. Why is th...
I have a workstation on this switch that is running WireShark and I need to get packets to it.  However the moment I turn on port mirroring the station loses IP connectivity to the network.  I tried Rx only, Tx only and both and all three settings kn...
tato386 by Level 6
  • 1838 Views
  • 2 replies
Is there a way to automatically change the port state (SLM 2008 switch) from enabled/100MB/1000MB  to the disabled state?The setting change must occur on certain times of the day.Or, if possible, based on port statistics (number of Mbytes sent/receiv...
I have a SRW248G4 switch that I want to edit the StartCfg.cfg file to use as a template for several new switches.  The content of the startcfg.cfg file looks to be binary or mostly binary.  Is there a way to get the switch to save and load the file i...
kmelcher by Level 1
  • 838 Views
  • 0 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
