- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
05-31-2022 01:35 AM
HI, I am looking to connectiong two (2) Webex room navigator touch panels to a singel room kit pro.
Reason; table is really long and the customer wants it...
Is this possible?
Can they mirror each other?
Solved! Go to Solution.
- Labels:
Conferencing
Room Endpoints
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-05-2022 11:44 PM
Yes, this is possible. You will either need to pair the Navigators to the Room Kit Pro over the LAN, or use a small PoE Switch between the Pro's Touch Panel network port and the two Navigators.
Please remember to mark helpful responses and to set your question as answered if appropriate.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-31-2022 10:07 AM - edited 06-02-2022 07:07 AM
I guess that the best option is to try it out. You can at least have multiple Navigators setup for the two different roles that they can have, desk or wall mount, so very likely it should be doable to have two with desk role.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-05-2022 11:44 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-14-2022 12:40 AM
I think that you can connect one to the POE port of the RoomKit and the other via a POE port in the a network switch.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-31-2023 08:50 AM
Could I use the same method to connect x2 table navigators on a Plus model?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-02-2023 02:08 PM
Yes, you can pair the second one across the LAN. Just make sure in the Plus' Configuration/Peripherals that Remote Pairing is turned on, and TouchPanels is set to 2 or Minimum1.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-02-2023 02:15 PM
The Pro actually has two PoE ports, so two Navigators or Touch 10s can be connected directly without a PoE switch or injector.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-07-2023 01:29 PM
Terminals are registered in CUCM!!
