Voice Systems and Accessories - Small Business
Upgrade your communication system with our Voice Systems and Accessories, perfect for small businesses.
Hi Guys,We have a client with an SPA900, SPA400 and 4x SPA942s. They signed up for a new SIP service through Nexvortex. All outbound calls work great, but an inbound call to either of their DIDs fails. The DIDs have been provisioned and I can see cal...
Very cool that CCA 3.1 is now alowing customization of the phones backgrounds.  The old method of modifying the XML file and TFTPing was a mess.   When I try to uplaod the files though CCA however I get an error that 'the selected image format is not...
dharig by Level 1
  • 1149 Views
  • 2 replies
Many of us use the CALL HISTORY | RECEIVED CALLS or MISSED CALLS feature built into the SPA525G2 phone. In its default configuration, in order to return a call, each user has to go through he time consuming and unnecessary process of pressing EDIT DI...
I have owned a UC520 since CCA 2.1   and each time you factroy default the unit and re-enter the generic SIP providor the incomming SIP calls are rejected with 500 Internal error.  Each time the fix was to remove a Voice Source Group Access list.  TA...
dharig by Level 1
  • 1723 Views
  • 6 replies
Helping a partner with CCA 3.1 SWP 8.1.0So everyone is probably aware that each Cisco IP Phone model display screen size is a little different, and if you want to customize the Setting: User Preferences:Background Images (from the phone)...the this r...
Hi There,I have been looking at the UC320 and how our organisation would go about generating an easy provisioing file that can be handed to customers UC320 maintainers for quick setup.I am able to get to the XML configuration by using the same method...
joshuap by Level 1
  • 668 Views
  • 0 replies
I seem to be having an issue that my intersite calling audio both recieving and sending has stopped working after the 8.2.0 upgrade - has anyone else had this issue?I tested it both going from an 8.2.0 site to a 8.1.0 then proceeded to upgrade to 8.2...
