Can you do more then one MOH on uc560? We're quoting a uc560, and potential client has 2 companies in house. They were wondering if we could setup 2 seperate MOH.. one MOH for company A and a seperate MOH for company B?
Using Cisco Small Business Office Manager and a UC540, when selecting a User under Users and Groups and entering Manage Users >> xxx, I'm not given a Save option for any edited fields. Save is inactive while Reset is the consistenly the only option ...
Currently, my data network is all static IP's 10.0.0.x. I connected the uc320, and aside from the other issue I posted here (great response by the way), all went relatively well, the phones all work, I can get into the web gui for the uc320, etc. I...
Running 7.4.8 on both a 504 and 525 and have found that using BLF when more than 3 users configured completly locks up the phones when the notify is sent, if 3 or less users are contained in the notify then no problem , have a sip trace if required
After upgrading my SPA504G to version 7.4.7 my BLFs are no longer working. If I downgrade to 7.4.6 they work again with no configuration change. Has the BLF configuration process changed with 7.4.7? I didn't see anything about it in the release no...
I'm looking to setup a UC320W setup for an organization that sounds to be the perfect size, and has the perfect need. The UC320w + 6 SPA504g phones fits perfectly in the budget of this 3 person tax firm, that expands to 6 people durring the busy seas...
Dear all,Urgent!!! 1>Do any body know that,the UC320 FXO Can't Show Caller ID after Connected MP-118 FXS,uc320's ip phone screen just show 'fx01 or fxo2 or fxo3",any body know how to solve on uc320.But before the SPA9000 connected with MP-118,it SPA9...
I used the CCA 3 for initial setup of a new site.I let it use the default IP range for the voice vlan initially and later went back and changed it. After the change the phones will not pick up an address via dhcp. If I hard code them they never regi...
Hi Cisco Team,From time-to-time I request feedback from the clients after an install, usually about 5 days after it is installed, below is a capture of the questions asked and the feedback received, to which I hope we can work on together.Q: /* St...
Trying to set up video monitor with CCA. I have a PVC 2300 up and running and can even see the device in the topology view in CCA. However, I can't seem to get the wizard to run.Any ideas?Thanks,Cole
Deployed a UC320 with 11 SPA303s and 1 SPA504G. The SPA504G shows extension 77101 on the display. The phone is able to make outbound calls, but call not receive calls. The UC320 has extension 100 programmed for the SPA504. We have reset the 504G ...
Hello, I have a user with a remote SPA525G2, VPN connected to a UC540.The user is experiencing the phone "locking up". The buttons do not respond.The screen appears normal with the user extension but there is no dial tone when the handset or speaker...
I've just taken delivery of a new UC320W for my small office. It replaces an aging BT Micro box (I'm in the UK), that did a lot of the same things the UC320 does (plus a few extras), but which was not the most stable product and it seemed time for a ...
After updating to 7.4.7 and 7.4.8 I found that the video monitoring links stopped working. You can see that there is an option for it, but when you select a video feed to see it does nothing.Reverting back to 7.4.6 corrects this behaviour.
Hi,I have enabled Single Number Reach for our users, but when we test it the calls do not transfer. The CLI looks like the following: /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; m...
