Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
HiI've 2 WAP4410 and would repeated the wireless signal from the AP1 to the AP2. Dumb Questions: :-)My Config:- AP1 configured as Access Point (Checkbox selected: Allow wireless signal to be repeated by a repeater with MAC of AP2)- AP2 configured as ...
Ours Sorry to say I have the same problem - happy that atleast others also have it, so maybe a quicker resolution.Clents: 1) HP nw8440 with Intel PRO/wireless 3945ABG, running Vista Business, all latest driver & Win updates (ok, missing the last ...
My partner wanted to know what are the functional differences between the 500 and 1100 Series WAPs? They typically use the 1131bg (Standalone, not the Lightweight) for almost all of theirjobs, but noticed that the 500 Series is quite a bit cheaper....
More firmware updates to address any outstanding or newly raised issues , or is V2 the current 'supported model' ?? Both versions are still being sold..
I recently purchased a WRVS4400Nv2 after my WRT54GX died. When I am hard wired into the router I am able to SSH into my linux servers. When I am connected wireslessly I can authenticate and it shows my my shell prompt but as soon as a I press a key...
Greetings of the day:Hello, I have a client who has three WAP4410N Firmware V 1.0.12 and Hardware Rev.12 all connected to an RVS4000 as a gateway, when using wireless clients to access wirelessly the management interface of all three only two open, ...
The network setup is as follows.(1) WRT350N supplying DHCP and wireless on SSID, configured as 1.1, channel 6(2) WAP4400N static IP 1.245 and 1.246 on same wireless SSID, channel 3 and 9There is no wireless securtiy setup.. yeah, literally a big hou...
I have 2 of these setup within 15 feet of each other in Bridged mode. When they go out I reboot the main building where the internet access is and everyone is wired to the network.Here is what I have setup and getting same thing:Linksys Switch SRW20...
Hey Shepner,Let me know if you figure it out. I have 2 of these in a Bridge between 2 buildings. Cisco supportreplaced them with 2 BRAND NEW units after 6 weeks of waiting, that do the same thing. Spentso many hours on these turds it is insane. th...
The problem is that I have been task to install a UC500 with an eight port switch, eleven 7921 wireless phones with eight AIR-AP521G-A-K9, and no controller.How can I get roaming to work on the Voice Vlan 100 for my 7921's? Thanks for your time...
Can I register my WRVS4400N wireless-n router? If so, how do I go about it. I am use to the consumer side and now have switched to small business, which appears to be a whole different ballgame. Mike
Hello all,VLAN separation on WRV200 is really weird or non functional or...If I configure two SSIDs and map them to different VLANs on different eth.ports how it is possible that I can see traffic from each other?And how it is possible that I can obt...
I have a customer who needs several of the standalone wireless AP's for three facilities. Which power adapters do I need to make them work, absent a POE switch? I'm assuming the part number options below all apply - just need to know which ones can...
