Networking
Collaborate with peers and Cisco on all aspects of your network, including Cisco Digital Network Architecture (DNA), routing, switching, and more.
Browse the Community
Cisco Catalyst Center
This community is for technical, feature, configuration and deployment questions. For production dep...
NFVIS Solutions
Join peers and Cisco experts to discuss Cisco’s Network Function Virtualization (NFV) products and s...
Switching
Meraki
The Meraki Community is now part of the Cisco Community.
Cloud Networking Platform
Topics related to Meraki cloud-managed networking, including Dashboard administration, full-stack de...
Networking Demo
Cisco Networking demo environments on dcloud, including Launchpad for partners and the Cisco Meraki ...
Join community contests and challenges designed for the Cisco Networking Community
Activity in Networking
Resolved! SG300-28P firmware update
Hi all,I have in my hand an sg300-28p with firmware 1.3.0.62 and bootloader 1.1.0.6. I want to put it in the latest version (I'm aware of the in-between I have to do because of new bootloader version) but I don't see any firmware for my switch.There ...
elwan by • Community Member
  • 18825 Views
  • 9 replies
Resolved! 9800 WLC - Local AP Mode and Central Switching
Hello......I have been running my 9800 WLC and 9178i AP for a while now. I want to add more AP's to the site and use the three SSID's on the same AP and on the secondary AP. This is all for my primary site. I am currently running Flex connect mode fo...
SG350-52P PC boards fired
We have 6 SG350-52P's the No. 3 quit. When taking it out of the rack heard things rattling around inside.  Opened up the case the inside top of the cover burnt and the all the boards behind the rj45 connections puffed.  I have seen a lot of equipment...
btentinger by • Community Member
  • 74 Views
  • 2 replies
How to configure HA in Cisco WLC 9800 L-F-K9
Current setup:WLC 9800-L-F-K9 (Active) → Core Switch (Primary) → Active Gateway → FTD Firewall → Router → ISPWe have purchased another WLC 9800-L-F-K9 and need to configure High Availability (HA) between the two controllers.The new WLC will act as St...
zhd27 by • Level 2
  • 1367 Views
  • 5 replies
Cisco BE7000M (M7) – NFVIS & CUCM Migration Guidance
Hello Everyone,We have received the following new Cisco hardware and licenses for our office, and we are planning to deploy a Cisco Unified Communications (CUC) solution.Available Hardware and Licenses:BE7M-M7-K9 – Cisco Business Edition 7000M (M7) A...
zhd27 by • Level 2
  • 60 Views
  • 0 replies
Cisco BE7000M (M7) – NFVIS & UC Deployment Guidance in CUCM
Hello Everyone,We have received the following new Cisco devices and licenses for our office, and we are planning to deploy a Cisco Unified Communications (CUC) solution.Available Hardware and Licenses:BE7M-M7-K9 – Cisco Business Edition 7000M (M7) Ap...
zhd27 by • Level 2
  • 59 Views
  • 0 replies
Resolved! C8221-G2 in production
Hi all, is anyone running the C8221-G2 in routing mode (not SD-WAN)?1. Which IOS XE release did yours ship with, and what are you running in production (26.1.x or 26.2.x)? Any bugs to watch for?2. Does a routed (L3) LACP port-channel on the flex port...
markacronin by • Community Member
  • 83 Views
  • 2 replies
Meraki devices stencils
Hello,Where can I get the Meraki devices stencils. We need to create some network documents using visio. Please suggest. I tried web search and not getting any specific useful information. Thank you
Annis by • Community Member
  • 221 Views
  • 8 replies
CCNP Enterprise Recert (350-401 ENCOR)
Hi,My CCNP Enterprise expires on 31st May 2026. I have left my recert quite last minute this time round.Cert Metric shows the CCNP Enterprise Expiry date of 2026-05-31. The actual certificate says "Valid Through May 31, 2026"If I pass my 350-401 ENCO...
eapolcapable by • Frequent Visitor
  • 3772 Views
  • 10 replies
OctalDart DART-8 extension cables
HI I have a customer asking why Cisco does not manufacture an extension cable for use between native DART-8 APs such as the 9174e and native DART-8 Octal Dart antenna such as the C-ANT9102 of more than 3m i.e. the AIR-CAB003-D8-D8=.Can I assume this ...
sbcoms by • Community Member
  • 83 Views
  • 0 replies
Share your Expertise
Level up by answering questions in your area of expertise.
Top Experts - Last 30 Days
