11-19-2012 04:10 AM - edited 03-16-2019 02:15 PM
I running CUCM with demo license is there a time limit to use this demo licenses?
Leonardo Santana
Solved! Go to Solution.
11-19-2012 04:47 AM
Cisco Unified Communications Manager contains a starter license that you can use to begin new installations of Cisco Unified Communications Manager before you install the production license. Starter licenses, which are available in limited quantities, have no expiration date. Please refer below link.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_5_1/ccmfeat/fslicense.html#wp1156540
Gnaneswaran.M
11-19-2012 05:27 AM
This is no longer true starting with ELM on CUCM 9.0. There are no licenses installed by default and ELM will shutdown the products after a grace period.
A 60 day grace period allows administrators to add users even if insufficient licenses exist within the ELM license pool. If sufficient licenses are not available once the 60 day grace period expires, then the Unified Communications application(s) will no longer allow any further changes; however, the application(s) will continue to function with no loss of service.
Unity Connection will outright halt services when the grace period expires.
Your only path for a permanent lab/demo would be to purchase an NFR kit.
Please remember to rate helpful responses and identify helpful or correct answers.
11-19-2012 06:02 AM
Hi Leondardo
No, at version 8.6 you will be fine. You will have 150 DLUs and 3 node licenses which will not expire. You will not however be able to upgrade your system as the demo licenses are removed if you do.
It's only at version 9.x that these licenses are replaced with a 60 day eval.
HTH. Barry
Barry Hesk
Intrinsic Network Solutions
11-19-2012 04:47 AM
Gnaneswaran.M
11-19-2012 05:27 AM
11-19-2012 05:30 AM
Thanks, i using CUCM 8.6
I have insert the DLU, in my case i waiing for the software license. So there is no problem?
Leonardo Santana
11-19-2012 06:02 AM
Hi Leondardo
HTH. Barry
Barry Hesk
11-19-2012 06:09 AM
Thanks!!
Leonardo Santana
05-26-2015 08:23 AM
Hi guy's,
I am having a CUCM 10.5,is there any chance to get demo license for 100 user's
Kindly advice
05-27-2015 01:44 AM
Hi Shah,
You have a grace period of 180 days after u install Call Manager 10
During this period, u need to get the permanent licenses.
Other way u visit cisco licenisng site and click on Demo and Evaluation to get below licneses
20 CUWL PRO Unified Communications Manager licenses
- 20 CUWL PRO Unity Connection licenses
- 5 TelePresence Room licenses
you won't be able to get 100 user licenses in Demo .
regds,
aman
12-17-2015 05:21 AM
hi
please i have cucm version 10 and my grace period will expire in 1 day , what will i do there is any way to expand this period for more 3 days until i receive my temp license , dose the cucm will shutdown or it will still work without the capability of registration any anther phone , please help me
regards
heba
12-17-2015 05:49 AM
Hi Heba,
you can refer the link which says
Licenses in the non-compliant state for Unified Communications Manager are enforced after a 60-day grace period. At the conclusion of the grace period, Unified Communications Manager enforces non-compliance with the following service degradation:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/9_1_1/ccmfeat/CUCM_BK_C3E0EFA0_00_cucm-features-services-guide-91/CUCM_BK_C3E0EFA0_00_cucm-features-services-guide-91_chapter_0100100.html
regds,
aman
07-05-2013 05:12 AM
By the way, with 9.x you need to order CM9.X-K9-LAB, SW CM 9.X Lab Only, 20 CUWL PRO, 5 TP Room after the 60 days eval.
03-14-2014 12:22 PM
Hi !
I've just installed CUCM 9.1 and I've applied for demo/evaluation licenses from Cisco using ELM (Enterprise License Manager).
Now I have :
20 X CUWL Professional (9.x) Unified CM
5 X TelePresence Room (9.x) Unified CM
20 X CUWL Professional Messaging (9.x) Unity Connection
ELM reports that above licenses are valid for 6 months and not for 60 days. Seems Cisco exended demo usage time to 6 months.
I don't know what happens after expiration or if I have any chance for time extention for my LAB licenses.
Konstantinos Pappas
Systems Engineer
02-12-2015 07:36 AM
What do you mean by not being able to upgrade?
