Network Management
Labels
Hello,Where can I get the Meraki devices stencils. We need to create some network documents using visio. Please suggest. I tried web search and not getting any specific useful information. Thank you
Annis by • Community Member
  • 621 Views
  • 9 replies
On a Layer 3 core switch that provides gateway interfaces (SVIs) for multiple VLANs, how can we configure SSH access so that the VTY lines only accept connections through the VLAN 10 gateway IP address? For example, SSH should be accessible via 10.10...
hs08 by • VIP
  • 398 Views
  • 9 replies
Resolved! SCP error
I'm trying to upgrade a router with CiscoWorks RME using SCP. It fails and says " SCP: [22 -> x.x.x.x:28475] send Privilege denied.".The privilege level for this user is 15. I have checked the firewall and it's not blocking the traffic. Any ideas on ...
When a failure occurs on an ISR900 router, we restore the backup file created using `copy startup-config tftp` to the router. In this case, do we also need to back up `vlan.dat` in advance and restore it as well? My understanding is that VLAN informa...
CHISHIUNG by • Spotlight
  • 466 Views
  • 4 replies
 Hi all,I have 2 IP SLA and track and each track have EEM when they are DOWN and UP. Sometimes both IP SLA down together and multiple times. This caused the EEM in aborted. How can we know why it is aborted ?No. Job Id Proc Status Time of Event Event...
We are aware and actively investigating issues with SAML SSO failures. Customers may experience log in errors with page not found. A workaround is removing the /login/saml/email_verification from the end of the URL. This is being investigated as a pr...
CallyH by • Cisco Employee
  • 510 Views
  • 1 replies
Resolved! SNMP at 5s and 6s
Hi There,Was wondering if someone has come across this before.I'm polling a couple very limited SNMP OIDs (ifHCInOctets/ifHCOutOctets of some interfaces) at high intervals on Catalyst 9300 class switches.At 5s, the ifHCInOctets/ifHCOutOctets is very ...
alexgill by • Visitor
  • 1394 Views
  • 7 replies
Hello everyoneI want to know if you change your clock configuration each year or not ? I mean what do you do to change the summer-time each year? Because the date and the day will change every year.I mean, this year the summer-time is : 10 Mar and 3 ...
Top Solution Authors
