Routing
Labels
I learned that MED is applied to outbound updates , dictating the best inbound traffic into the AS, but I saw the vice-versa is also true like you can apply med for indbound updates also and it works the same right??
So I read this on official cisoc routing and switchin route 300-101 "Cisco IOS lists a null value for Local_Pref for eBGP-learned routes by default" , but I saw in my lab that the local preference is not null it's 100. What it means??
Hey There,I get there is duplication of data but I can't figure the math on this one and what is happening.  Please help.I am trying to copy a Port-Channel of 4*1 gbps interfaces to a single 10gbps interfacemonitor session 1 source interface Po100mon...
Alex-Pr by Level 1
  • 223 Views
  • 3 replies
Hi AllWe recently ordered a cisco 8300 router, it did not take many of the commands so I had to change the licence boot level.How do the licences work with these routers, are they shipped with it or do you just change the boot level and accept the EU...
Please i hope you can help me, I need the CAD drawing (DWG, DXF, or STEP) for the followings components:   -          IE 3000-8TC  -          PWR-IE65W-PC-AC=   Thanks in advance, regards!
Resolved! vPC on Nexus 9000
Is't ok on nexus 9000 i want to add command fast-convergence on vpc peer, also vpc peer has  delay restore and auto-recovery, read some article fast-convergence heplfull vpc domain 1delay restore 150auto-recoveryfast-convergenceReduced recovery time ...
Mlex1 by Spotlight
  • 382 Views
  • 7 replies
I am trying to connect a PT router to a WRT300N wireless router with a crossover cable or straight through. I want the PT router to be the gateway. I have the WRT300N router set up and connected to 2 PCs using WPA2 personal encryption.I am not sure h...
Unanswered Topics
