Routing
Labels
Hey There,I get there is duplication of data but I can't figure the math on this one and what is happening.  Please help.I am trying to copy a Port-Channel of 4*1 gbps interfaces to a single 10gbps interfacemonitor session 1 source interface Po100mon...
Alex-Pr by Level 1
  • 206 Views
  • 3 replies
Hi AllWe recently ordered a cisco 8300 router, it did not take many of the commands so I had to change the licence boot level.How do the licences work with these routers, are they shipped with it or do you just change the boot level and accept the EU...
Please i hope you can help me, I need the CAD drawing (DWG, DXF, or STEP) for the followings components:   -          IE 3000-8TC  -          PWR-IE65W-PC-AC=   Thanks in advance, regards!
Resolved! vPC on Nexus 9000
Is't ok on nexus 9000 i want to add command fast-convergence on vpc peer, also vpc peer has  delay restore and auto-recovery, read some article fast-convergence heplfull vpc domain 1delay restore 150auto-recoveryfast-convergenceReduced recovery time ...
Mlex1 by Spotlight
  • 357 Views
  • 7 replies
I am trying to connect a PT router to a WRT300N wireless router with a crossover cable or straight through. I want the PT router to be the gateway. I have the WRT300N router set up and connected to 2 PCs using WPA2 personal encryption.I am not sure h...
I have situation which I apparently do not understand. NAT Translations show 0 in following case:show ip nat translations Total number of translations: 0nat-limit statistics:max entry: max allowed 0, used 0, missed 0longest chain in local hash: 0, av...
kyoto by Level 1
  • 575 Views
  • 3 replies
Hi! I have a problem with VRF NAT translations.We have a cisco 1111 router with following configuration:ip vrf WILDNETip vrf WILDNET_PTip vrf WILDNET_TMinterface GigabitEthernet0/0/0description outsideip vrf forwarding WILDNETip address 1.1.1.10 255....
Unanswered Topics
