I learned that MED is applied to outbound updates , dictating the best inbound traffic into the AS, but I saw the vice-versa is also true like you can apply med for indbound updates also and it works the same right??
The content you are looking for has been archived. View related content below.
So I read this on official cisoc routing and switchin route 300-101 "Cisco IOS lists a null value for Local_Pref for eBGP-learned routes by default" , but I saw in my lab that the local preference is not null it's 100. What it means??
Hello I had trtied to apply this scenario to my FPR1010 but either due to lack of understand or simply did not fit my needs, I decided the FPR1010 was a Firewall {obviously) and decided to let it be such and work on the ISRC1111. What I have posted b...
Greetings I have a N540-24Z8Q2C-M and start receiving log message from OBFL flash 0/RP0/ADMIN0:Dec 17 14:12:57.777 AST: mediasvr[2623]: %MEDIASVR-MEDIASVR-4-OBFL_FLASH_ACCESS_FAILED : OBFL flash access failed, error : Read-only file system0/RP0/ADMI...
Network scenario: ISP>CISCO Router> CISCO FTD > Core SW >Access SW > Serverwe have two public ip like 203.76.64.16/28 and like 203.76.64.64/26 here only 203.76.64.19 is my end and also 203.76.64.64/26 is used for only one to one NAT in FTD for my few...
Hey There,I get there is duplication of data but I can't figure the math on this one and what is happening. Please help.I am trying to copy a Port-Channel of 4*1 gbps interfaces to a single 10gbps interfacemonitor session 1 source interface Po100mon...
Hi Team,We are experiencing an intermittent IPsec tunnel hang between a Cisco 8000V router hosted on AWS and a Palo Alto firewall.Multiple IPsec tunnels are configured on the same Cisco router and are stable; however, only one tunnel to the Palo Alto...
Hi AllWe recently ordered a cisco 8300 router, it did not take many of the commands so I had to change the licence boot level.How do the licences work with these routers, are they shipped with it or do you just change the boot level and accept the EU...
I know routers often rate limit the generation of ICMP error message to keep CPU load manageable. Does anyone know if there are routers that also rate limit the forwarding of ICMP messages? In particular, I'd be interested in Cisco routers.The reason...
Please i hope you can help me, I need the CAD drawing (DWG, DXF, or STEP) for the followings components: - IE 3000-8TC - PWR-IE65W-PC-AC= Thanks in advance, regards!
Is't ok on nexus 9000 i want to add command fast-convergence on vpc peer, also vpc peer has delay restore and auto-recovery, read some article fast-convergence heplfull vpc domain 1delay restore 150auto-recoveryfast-convergenceReduced recovery time ...
I have typed below command, normally it has to let me enter yes or no but in mobaxterm when i press enter it is jumping to next line R1#, skipping Reset ALL OSPF processes? [no]:anyone faced this? pls help. R1#clear ip ospf processReset ALL OSPF pr...
IN-TN_CHN_BNG-INFONET# show interfaces po10 human-readablePort-channel10 is up, line protocol is upHardware is 10GEChannel, address is 5c5a.c700.8ec9 (bia 5c5a.c700.8ec9)Description: ## CONNECT-TO-INTERNET ROUTER ##Internet address is X.X.X.X/XMTU 92...
I am trying to connect a PT router to a WRT300N wireless router with a crossover cable or straight through. I want the PT router to be the gateway. I have the WRT300N router set up and connected to 2 PCs using WPA2 personal encryption.I am not sure h...
Hi, I know that Cisco Edge 340 is a retired product. If anyobe can provide ISO file I can try recovery for Media Player as it displays Error in Hardware validation. Regards, SA
| Subject | Author | Posted |
| 12-05-2025 03:27 AM | ||
| 11-13-2025 04:57 PM | ||
| 11-09-2025 09:51 PM | ||
| 11-06-2025 06:09 PM | ||
| 10-26-2025 02:24 AM |
| User | Count |
| 7 | |
| 3 | |
| 3 | |
| 3 | |
| 2 |
