Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 1503 Views
  • 1 replies
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant  - Discover support content and options for your gearSupport page index - Contains ...
  • 2941 Views
  • 1 replies
  • 15 Helpful votes
Hi. Today I tried to config a HSRP group on a Vlan A and VRRP on a Vlan B, in that order. But, When enter vrrp 30 ip x.x.x.x, it showed me an error telling me that I'm wrong about FHRP group number. This was on a Cisco3560. To solve this and be able...
Hi, How to enter in psbl mode is ESC send dosn't work? The psbl cursor appears, but I can not enter the sending ESC. In this case, it does not appear in the text .... Press ESC. Thank you! Tony "PSPBoot1.4 rev: 1.4.0.6(c) Copyright 2002-2008 Tex...
Hello, I have two subnets in my office as below, 192.168.1.0/24 192.168.2.0/24 I need all the systems should communicate with each other. There are 4 switches of 48 Port and all are uplicked with each other. I just found that I can create VLAN routin...
mohdazim88 by Beginner
  • 1040 Views
  • 13 replies
I got my first 4948 switch.  I configured my management port Switch>show ip interface brief Interface                  IP-Address             OK?           Method          Status              ProtocolVlan1                       unassigned            ...
Hello Experts, I am facing a problem we have 2 SF300 switches, they are connected by SFP module. we can ping from one end to another end  through PC. But my client have a software (type of Monitoring) on a PC its connected on SW1 and the SW2 have so...
