Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2947 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4538 Views
  • 1 replies
  • 16 Helpful votes
Hi,With the new migration to Energywise switches (and others) I was wondering if the upgrade of IOS in a 2960 for example to get the Energywise Compliance is a free upgrade, or does the end user  have to have a SmartNet software contract?Thanks in ad...
bjames by Level 5
  • 2627 Views
  • 1 replies
I'm unable to correctly set the time on a h/w version 3, firmware version 1.01 SLM2024 switch. After attempting to do so, the unit is set to an arbitrary date/time such as 01-02-00 @ 11:19:19 (the current date/time on my unit). Attempts to correct th...
Greetings would someone be able to clarrify please what direction Cisco is taking in regards to the SMB switching product line as i am starting to get somewhat confussed.From my estimation we currently have the following available for the SMB market,...
I have a SRW224G4. I can create multiple VLAN's but when I try to create another vlan interface and add an ip address to it, I get the error message "ip address table overflow". Is this switch limited to having only 1 IP address? I would like to have...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
