Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board from June 18th - July 18th. These dates are subject to change pending progress. This in...
CoreyP319 by Cisco Employee
  • 83 Views
  • 0 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5468 Views
  • 1 replies
  • 16 Helpful votes
Resolved! POE Switch
Is the SF100D-08P unmanaged POE switch a discontinued model? If so, is there a comparable replacement? I'm looking for a reasonably priced switch to power WAP access points.Sent from Cisco Technical Support iPad App
                   I need a little guidance. Trying to connect SG500X-24 switches to a new installation of MOE (four sites)provided by Century Link.  Anyone have any experience with this?  I have tagged the uplink port with the MOE vlan, but traffic ...
I am trying to get QoS for my VoIP system setup on several SGE2000p switches and have got a question...How do I define the ACL for RTP? As far as I can tell it will not let me enter a UDP port range for the RTP traffic... And I cant imagine creating ...
Please send me the best propose for the following specification :Switch will be used for CCTV system for up to 20 Cameras.•1)      10/100 BaseT Fast Ethernet Ports ( at least 14 ports )•2)      10 /100/1000 BaseT Gigabit Ethernet Ports ( at least 12 ...
Hello Community,I have definded several VLANs and the coresponding IP Adresses on the SGE2000. The static routing works fine. On one VLAN there is a Windows 2003 DHCP Server which I have defined as DHCP Relay Server (Option 82), but no packets are re...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
