Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2890 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4458 Views
  • 1 replies
  • 16 Helpful votes
Hi,Fromhttp://www.cisco.com/assets/sol/sb/Nikola_GUI/SG_300-28P_v1_1/config/home.htmIP Configuration > Management and IP Interfaces > IPv6 TunnelI would like to know how i can use this?.If i enable isatap on switch and a successful connection with is...
cisco4239 by Level 1
  • 740 Views
  • 0 replies
Why does the sx300 series only displays ping and traceroute results in 20ms intervals (see below)? The example in the CLI manual shows "regular" results. These 20ms intervals are not helpful for troubleshooting.  This is version 1.1.0.73 on an sf300-...
cavan1975 by Level 1
  • 2150 Views
  • 2 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
