Switching
Get 20% off switches when you combine Cisco solutions
Labels
Hi. I recently attempted to update 2x C9500 in SVL via DNAC from 17.6.4 to 17.9.4. It initally looked to be progressing all ok with being distributed then activated on each unit. DNAC then stated process had failed. I manually checked switches via CL...
Marco111 by Level 1
  • 89 Views
  • 3 replies
Trying to authenticate I have this error as shown, can anyone help me!*May 11 12:38:20.482: %RADIUS-4-RADIUS_DEAD: RADIUS server 192.168.100.3:1812,18 13 is not responding.*May 11 12:38:20.482: %RADIUS-4-RADIUS_ALIVE: RADIUS server 192.168.100.3:1812...
Jason2005 by Level 1
  • 143 Views
  • 3 replies
Hi, I'm trying to prefer R2 route for the multicast traffic (without using static mroute)  from R1 (receiver) to R4 (source):Receiver (R1): 10.10.10.10Source~(R4): 10.0.45.5I'm completely new to multicast and still trying to understand how it works b...
D@1984 by Level 1
  • 86 Views
  • 1 replies
  • 1 Helpful votes
We have several remote locations with their own L3 switch that we use for routing. Some have direct fiber to our central core others uplink via another router and use VPN to tunnel back to our central office firewall.Edge switches at these locations ...
Hi, i have problem of synced betewin my 2 switchs nexus 7.0.3.i7.3I use feature BGP, LACP and VRRP (also VPC etc..)But it's impossible of configure correctly the protocolI have many errors :One : In log :%ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 9-1...
JulianDD by Level 1
  • 1268 Views
  • 51 replies
I have a couple of switches that are trunked via a LAN cable from another switch. I noticed that these switches sometimes have a hard time to SSH into. I get the error: "Connection timed out". After a while and a few tries I can connect just fine. I ...
Rick001 by Level 1
  • 774 Views
  • 24 replies
Work on a Mac for my lab exercise, I have followed all the instructions for an SSH connection, including configuring line VTY 0 4I have read all the posts on here and nothing seems to fix the error" connection closed by foreign host".
Hi all, I have a cbs350-8p-e-2g with version 3.4.0.17, every time to reload it will show below message but I didn't make any configuration changes. Is it a bug ?"You haven't saved your changes. Are you sure you want to continue ?"
