Switching
Labels
Hi,We have an office with two cabinets. One is where our primary switch is located in the basement cabinet and there is a small cabinet on the first floor. Uplink for the first-floor switch is from the basement cabinet switch, and both are Catalyst 9...
How to get missing Visio stencils?I am getting new CISCO Components (Nexus 93180YC-FX3, 93108TC-FX3P, 9332D-GX2B, C8500-20X6C). Unfortunately, visio stencils is missing from the library.Does anyone know where I can get it from?Thank you
Folks, I have been trying to upgrade a list of Catalyst 9200 series switches through DNAC. More than 90% of switches have been successful. But the remaining got failed. Upon checking DNAC, attached is the error reason it is telling.I have rebooted fe...
Hi, i was facing an issue with NTP sync in 3850 switchShow ntp statusClock is unsynchronized, stratum 16, no reference clock sh ntp associationsaddress ref clock st when poll reach delay offset disp~172.16.143.252 .TIME. 16 - 64 0 0.000 0.000 15937.~...
I have a catalyst 9300 switch running 17.12.04.  When NTP is configured, it can see its two sources. But it incorrectly lists them as being stratum 16. eg; #sh ntp assoc address ref clock st when poll reach delay offset disp~10.70.240.40 .TIME. 16 - ...
jmcgrady1 by Level 1
  • 90 Views
  • 1 replies
Not sure that I've seen this before. On Cat 9300s (v 17.15.3), I keep getting an ssh disabled status, when doing a sh ip ssh command. I've tried regenerating the crypto keys, and lowered the modulus, bit still no-go. Any ideas/suggestions would be ap...
Hi All,I wanted to understand why switch wont form a Trunk if both sides are dynamic auto.I have done the simulation lab and can see even dynamic auto sends a negotiation message.Just wanted to understand what headers switch will check to make the po...
jpduminy by Level 1
  • 109 Views
  • 1 replies
So today I had an SSH session going to my ISR 3925 SEC/K9 running IOS version 15.7 and I suddenly lost the connection.  When I tried to reconnect I received the error in Putty stating that the connection was refused.  I quickly obtained a console con...
jcone by Level 1
  • 57005 Views
  • 10 replies
Hi, Peeps,I have a Cisco Catalyst 2960X and early today I upgraded the firmware, upon reloading, the switch did not boot anymore, I tried the following workarounds:1. Pressing the Mode Button for 15 secs2. Power cycling the switch3. Trying to do the ...
tenj0u05 by Level 1
  • 10357 Views
  • 40 replies
