Switching
Labels
Hello, Cisco Community!I’m really happy to share that I’ll be hosting the Cisco Community Lab Series, a brand-new hands-on learning journey designed to help you build practical networking skills step by step.Every Thursday at 8 PM EST, I’ll post a ne...
I am trying to setup an IP HELPER-ADDRESS per SVI but clients are not getting IP address from the assigned DHCP Server in the IP HELPER Address.  C1300-24XT has also different syntax or argument in declaring IP HELPER-ADDRESS.Catalyst 1300 Series Man...
iamroy by Level 1
  • 1015 Views
  • 21 replies
I have an extensive network that I care for on-site and I have run into a problem that is baffling me.  We have a single layer 3 switch that handles inter-VLAN routing with several large layer 2 switches that are used as distribution switches for the...
jmalueg by Level 1
  • 124 Views
  • 4 replies
I just did try to upgrade this devices to new IOS 15.2(7)E13 and are failing to take this IOS, the worst thing is the devices back (ROMmon) mode. it cannot locate a valid Cisco IOS software image to boot from. Before we do any reload on this devices ...
cakramer by Level 1
  • 113 Views
  • 2 replies
Hi,we do have migrated our Cisco 6807 to cisco C9606R.we are in version 17.12.5.Since we have migrated we have a problem with Hitachi server Hearbeat connected on C9600-LC-48YL line card.we have the following configuration :NAME: "FiftyGigE1/1/0/20",...
jerome-mi by Community Member
  • 270 Views
  • 10 replies
Hi all, as a beginner I know this diagram might be too much and I aim too higher but I want to know if the diagram is correct and if i can configure so it will work properly.  So I need to make a project for uni. The project is to design a high redun...
Duras by Community Member
  • 169 Views
  • 2 replies
we have a 9407 and several small business edge switches, we recently had an issue where we lost internet connection in the whole facility, we started troubleshooting using elimination; we were able to identify the switches that created the issue. How...
Hi everyone,  I’m experiencing a strange issue on one of our Cisco switches: several interfaces (e.g., `GigabitEthernet2/0/5`, `2/0/9`, `2/0/11`, `2/0/13`, `2/0/14`, etc.) are continuously going **up and down every few seconds**.  I dont have any hub...
chpmotry by Level 1
  • 272 Views
  • 9 replies
IOS-XE Update Failure (Catalyst Center)We are trying to update the equipment, running in install mode, and it fails deployment due to lack of space. The command: [ install remove inactive ] does not correct the problem. Is there a document that lists...
I have 2 kron policy-list and 2 kron oneshot occurrence's happening for updating IOS-XE, 30 minutes apart from each other.  One of the kron jobs stays in the running config after it has successfully been completed and in kron Scheduler and looks like...
Todd-NG by Community Member
  • 92 Views
  • 0 replies
Hi. I am studying for the CCNP Encor and up until now I have been using GNS3 and eve-ng. I'm now looking at purchasing small physical switches as I am tired of learning that not all commands/functionalities work on simulated environments. Due to spac...
Rygo by Level 1
  • 136 Views
  • 4 replies
Hello Together,we have a Catalyst 9500 Core Switch and I wan to Isolate a specified VLAN (VLAN 5) deny to connect to all other VLAN. Here is a simple configuration and explanation what the result should be.VLAN 2 (Server) 10.1.2.0/24 Gateway VLAN int...
ralpho1 by Level 1
  • 110 Views
  • 1 replies
I have a customer who is struggling with the Thumbscrews that are used to secure these cables to the routers.   I am trying to find out if there is a part number associated with them and if it is possible to purchase replacement screws.     Or if the...
sfein by Level 1
  • 306 Views
  • 3 replies
