Unified Computing System Knowledge Base
Knowledge Base Articles
****UPDATE July 2021   The HUU images launched with our C-Series M6 Rack Servers are now compatible with the following USB creator toolsets:   Tool name Tool link  Supported on Windows Supported on Linux Supported on Mac  UEFI mode UEFI secure mode L...
To ensure the correct installation process is being followed for Cisco Compute Hyperconverged with Nutanix, please refer to the following flowchart to choose the correct documentation for the system being installed:    This document covers the ISM de...
beveritt by Cisco Employee
  • 54815 Views
  • 20 comments
  • 16 Helpful votes
One of the unappreciated features of the Cisco C-Series server is the ability to carve up the VIC into multiple virtual adapters.   This allows you to apply things like jumbo frames and COS to adapters on the same physical link.  It also makes dealin...
The following Cisco UCS Platform Emulators are available for download from Cisco: Current Cisco UCS Platform Emulators CONFIGURATION IMPORT NOTE:  Importing configuration backups (All, System, or Logical) taken from the UCS Platform Emulator (UCSPE) ...
ericwill by Cisco Employee
  • 604861 Views
  • 135 comments
  • 137 Helpful votes
To ensure the correct installation process is being followed for Cisco Compute Hyperconverged with Nutanix, please refer to the following flowchart to choose the correct documentation for the system being installed:    This document covers the UMM de...
  • 28086 Views
  • 2 comments
  • 11 Helpful votes
UCS PE supports uploading B-Series and C-Series server firmware bundles.  Because of the large file sizes of the firmware bundles, UCS PE only supports uploading of stripped-down versions with only the firmware metadata (not the actual firmware binar...
  • 64419 Views
  • 30 comments
  • 38 Helpful votes
A Field Guide covering advanced network configurations for Cisco Compute Hyperconverged with Nutanix systems. This guide covers network configurations with disjoint layer 2 networks north of the Cisco UCS domain, i.e. two distinct physically separate...
  • 5380 Views
  • 0 comments
  • 4 Helpful votes
Top Contributors
