Comprei Um UC 500 mas não consigo configurar aparelhos do Modelo SPA 941, no modelo SPA502G configura corretamete, verifiquei que tem como fazer upload de outros modelos de telefone mas não encontro em lugar algum, alquem tem ideia o...
I am unable to get IP Communicator to register on my UC520. My guess is there is a problem with the routing somewhere, but have not been able to resolve the issue. So I'm turning to the community for help.Network is set up as follows: modem --> rou...
Hello,for testing of some software I need first to make sure that the analog phone connected to the SPA3102 will receive an incoming call.I have an analog line that comes from Alcatel Omni PCX4400. 1. The plain analog phone connected to the line RING...
I have been trying to connect the above phone to my 320 with no success - It just will not register.Tried hard reset, no luck,Tried factory reset, no luck.Tried manully entering the MAC address, no luck.Unit is on same switch as other working phones....
How can I export a personal directory of the spa phones? I do not see them in the spacfg.xmlWhat I want is a simple way to push some caller id names into all phones at a company. Using the xml directory does not get the caller id.Sage
On an SPA 525g2, can speed dial be configured to use a calling card? That is, to first dial the calling card access number, pause, press 1, then enter a regularly dialed number ?
Can anyone tell me how to stop our SPA303 phones from continuously rebooting, I believe they keep re-provisioning every 24hrs and its becoming a extremely annoying.
Hi We have tried to register SPA525G and SPA504Gwith 3rd party SIP server, but it shows Failed(No Responce), I used the same IP and tried to register with Xlite, it was successful, i'm wonder why this phones are not registering with same Public SIP s...
A client has requested that we enable a group of SPA303-G3's to show some kind of prompt or name on their screen when a particular DDI is called.This is so that they can answer the incoming call as a particular department within their company.The pho...
Note: UCSS service for BE 5000 cannot be used on BE 6000. Please refer to the following link for details of the ordering process: Link does not function
hello,I use windows 8 64 bits , what is the version appropriate of vpnclient-win-msi?
HelloWe have recently purchased UC320w with 4 SPA525G phones.We are connected to outside with one BT telephone line which I have connected to FXO1 socket at the back of UC320w. I have two Problems :1) Originally when we wanted to call any external ...
Hi to allFax to email:I am wondering with Fax to email feature if is mandatory to have1) our own smtp server(it would not work if we set the ISP smtp right?)2) we need a fax machine connected to FXO?(This is mandatory for only incoming calls or its...
Hi All,Looking for assistance \ guidance on trying to get the routing correct thus to reach each sites devices.I have attached a network diagram to help you understand my setup:I can establish the link between both sites and ping both the 10.54.8.1 a...
Hello everyone!My question is, does SRTS mode supports third party SIP IP phone especially SPA302D?
